Old 02-21-2011, 11:39 AM   #1
Basement Shower Drain
Hi all
I am new here and am hoping that someone could help guide me a little on my basement reno.
I am currently working on my shower drain which was roughed in by the builder. They left a 2' x 2' access in the concrete floor and the capped pipe was buried under stone. After digging it out and taking measurements I attempted to plumb the drain to finish 1 1/4" above the floor for the stand up shower.
There are two issues. One being the small access which doesnt give me much room to dig up underneath the pipe. The pipe is also pretty much at ground level so I would have to dig down atleast a 1/2 foot to accomodate the p-trap. I came up with a configuration to allow for the trap to end up above the drain line but I am worried that it wont drain properly. I have included a rather crude drawing of it using paint but it should give you an idea. I poured a bucket of water down it and it seemed to drain quite well and held water for a few days.
My other issue is after gluing everything together the finished drain has a slope on it that matches the slope of the drain pipe. The trap has to be cut out and redone to get it level. How do I accomodate for this slope? Should it just be done when gluing together since there is some play in the sockets? Or am I missing something easier?
Thanks in advance!
bigbran is offline   Reply With Quote
Old 02-21-2011, 06:22 PM   #2
going thru a trap and 3 90's pretty much means you are screwed if you ever have to cable the drain. Dig below the main line, lower the trap, get rid of all those turns.
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
bigbran (02-22-2011)
Old 02-21-2011, 08:13 PM   #3
call me E
TheEplumber's Avatar
dig under the slab, cut the pipe, dig a hole for the trap. Loose the 90's
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 02-22-2011, 10:21 AM   #4
Sounds good - will do.
What about removing the slope once you get to the finished drain? Would a 22 1/2 work or can it be done just by using the sockets and take it out while gluing?
Shower drain not centered for new fiberglass shower pan keyboarder Plumbing 9 12-01-2010 09:30 PM
Washer Backing up into basement shower Durt Ferguson Plumbing 21 08-26-2010 10:41 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
Basement Shower smells wdodds Plumbing 7 11-15-2009 09:31 PM
Basement bathroom shower drain conversion coyotewaits Plumbing 1 01-08-2009 02:17 AM
