Basement Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2013, 12:12 PM   #1
basement shower drain
working on my basement bathroom. I went to install shower pan this morning got everything hooked up and together. Decided I would pour some water down the shower drain, and much to my surprise the water did not go anywhere. the drain line is holding water. the house is brand new only a year old!! I removed nthe cap for the first time this morning, so nothing should be down that line at all. The toilet drain is working just fine. I am a little confused as to what is going on here. Please help
Dan
firetruck12 is offline   Reply With Quote
Old 08-17-2013, 12:34 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
There is a trap below the floor in the drain. It is supposed to hold water to block sewer gases. Keep pouring water and see if it drains.
Coastal South Carolina
Old 08-17-2013, 12:47 PM   #3
I did do that and the water is at the top of the pipe and has not dropped at all it simply just isn't draining!!!
Old 08-17-2013, 07:50 PM   #4
DIY staff
Rewards Points: 7,174
You have a problem---Try rodding the pipe and see if it's plugged with construction debris---
Basement shower drain jdm127 Plumbing 6 05-18-2013 06:46 AM
Water backup into basement floor drain after jetting lateral and sanitary sewer sm2327 Plumbing 4 04-01-2013 01:18 PM
setting a shower drain Jackets Plumbing 16 05-10-2012 09:48 PM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
Basement bathroom shower drain conversion coyotewaits Plumbing 1 01-08-2009 02:17 AM
