Basement Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-16-2011, 11:02 PM   #1
Basement shower drain
Im replacing a leaking fiberglass shower with a custom tiled one in my basement. The old one is all ripped out and I am down to concrete floor with a 2 copper drain pipe extending up about 1 . (IMG_5557.jpg) I cant seem to find a suitable drain. They all seem to be too big. They all seem designed to fit larger (and PVC, not copper) drain pipe, and also seem to be at least 4 high. (like drain1.jpg and drain2.jpg)
If I use something like a fernco fitting to add a length of bigger pvc to use one of these commonly available drains Ill end up 6 or 7 above floor at least.
Is there some solution short of chopping out the embedding concrete floor? It seems a drain sort of like used for bathtubs, that slips down inside with a sealing collar would be great. But I havent seen anything like that suitable for a tiled shower, with weepholes.
Thanks.
DanAK is offline   Reply With Quote
Tags
shower drain , tiled shower drain
Shower drain not centered for new fiberglass shower pan keyboarder Plumbing 9 12-01-2010 09:30 PM
Washer Backing up into basement shower Durt Ferguson Plumbing 21 08-26-2010 10:41 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
Basement Shower smells wdodds Plumbing 7 11-15-2009 09:31 PM
Basement bathroom shower drain conversion coyotewaits Plumbing 1 01-08-2009 02:17 AM
