Basement Shower Addition, Venting Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2012, 10:02 AM   #1
Basement shower addition, venting question
Hey all,
I am in the planning stages of a basement and bathroom remodel and i wanted to get some opinions on my shower plans (see picture).
would this plan work?
again, we're assuming i slope everything a min of 1/4 inch per foot and not creating an S trap in the shower drain. Would this diagram pass?
fyi, it connects just downstream of a 4" line (a toilet isn't too far away) to which it will connect.
Thanks for any help youcan give me,
-jsv
jsvelte is offline   Reply With Quote
Old 05-14-2012, 06:18 PM   #2
Any comments?! Thanks!
Old 05-14-2012, 06:34 PM   #3
If the pipe going up behind the shower is just a vent, then you have a horizontal dry vent below the flood rim of the fixture, which is frowned upon most places, or all places, I do not know. I would recommend installing the trap higher, running it to the vertical vent pipe, using a sanitary tee in the vertical pipe, and a long sweep 90 under the tee. I hope this makes sense. Good luck
broox is offline   Reply With Quote
Old 05-14-2012, 08:20 PM   #4
DIY staff
Rewards Points: 7,174
Drawing shows vent pipe lower than drain line---it will flood and fail to work.
Raise vent line above the drain line---add the T as close to the P-trap as is practical.
Old 05-14-2012, 08:41 PM   #5
Rewards Points: 616
this is a better option
ok how do i add a thumbnail and what is a draw program that can be used
jaydevries is offline   Reply With Quote
Old 05-15-2012, 02:06 PM   #6
That configuration will not pass code. The plumbing code requires the base of every stack to be washed.
Originally Posted by jsvelte View Post
Hey all,
-jsv
Skip Harper is offline   Reply With Quote
Old 05-15-2012, 08:02 PM   #7
Rewards Points: 582
Hey all,
-jsv
sorry won't work...vent will flood....has to be higher than drain line...ben
Old 05-15-2012, 08:47 PM   #8
Guys, thanks for your replies, i'm going to have to rethink my plan. I like jaydevries idea, i will see if it will work. Maybe i'll have to raise the shower base....
thanks again everyone for your input,
-jsv
Old 05-16-2012, 12:13 AM   #9
Rewards Points: 616
you can also do this if it will help
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
beginner's question about shower fixtures diy'er on LI Plumbing 6 02-19-2012 11:05 PM
Shower Addition to Bathroom - Drain Tie-In Question (B.C.) sprusgoose Plumbing 2 02-09-2012 01:47 AM
How do you install a walk-in shower in a basement with floating walls? ronquillor Tiling, ceramics, marble 1 02-20-2010 05:57 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
