Basement Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2010, 08:16 AM   #1
basement shower
I have been reading some of the posts regarding a basement shower drain, but I wanted to ask my own questions so here we go:
I want to add a shower to a half bath and use the existing sink drain. I assume it is vented since we have no smell in basement though at high volume water drains quite slow( maybe clogged up from washer?). Is it possible to set the shower in top of that drain and also connect the sink and washer? Would you guys, that have experience, suggest something like that?
AL787 is offline   Reply With Quote
Old 12-02-2010, 11:38 PM   #2
what size pipe is coming out of the floor for your drain? if it's 1.5" than you can't put a shower as it requires 2". If you are unsure about how much work is going to be involved find a plumber with a free or a cheap estimate and see what he thinks. There are a number of things that need to be considered before switching things around like that.
and also welcome to the forums
immeraufdemhund is offline   Reply With Quote
Old 12-03-2010, 08:15 AM   #3
thanks
I definitely have a 2 inch pipe coming out, sink and washer is hooked up to it.
I will follow your advice and get a quote, but I was thinking about putting a shower on top off this drain because the bath is right next to it, I just wasn't sure if the pipe will be able to accommodate 3 devices
looks like a metal pipe coming from the floor
Old 12-03-2010, 05:26 PM   #4
Rewards Points: 150
You got me confused, a shower has to have a trap under it, how do you plan on adding the other fixtures?
braindead is offline   Reply With Quote
Old 12-03-2010, 09:11 PM   #5
that's why I recommended the getting a quote, amongst other things. Changing from cast or galvinized can be difficult to do properly with just normal house tools. If you hire a contractor to do it he'll have access to tools (either because he owns them or can rent them for cheap) draw back is, it is going to be expensive.
I don't think you'll be able to have 3 fixtures with that shower because you'd have a wet vent, and those typically are not allowed, but check with the contractor and see what he says.
Basement shower plumbing question. medicmike Plumbing 5 01-28-2012 04:40 PM
Installing shower & sink in basement Sporty40 Plumbing 1 10-09-2010 05:42 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 02:55 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
