Basement Rough-in; What The Heck Are These?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2013, 11:36 AM   #1
Rewards Points: 31
Question
Basement Rough-in; What the heck are these??
So i'm in the process of designing my basement in Auto Cadd and i would like to know which is what... Not sure if one is a drain for a shower, vent for shower, toilet, sink drain... I just don't know... Can anyone help??
Also, since the left of the bathroom rough in is partially under the stairs, i'd like to know where i can find certain code requirements for bathroom design. Minimum distances from sink to toilet, toilet to shower, do i need an exhaust fan, what is the minimum size of a bathroom need to be, and anything else i need to know.
Thanks for looking!
Basement Rough-in; What the heck are these??-rough-in5.jpg   Basement Rough-in; What the heck are these??-rough-.jpg   Basement Rough-in; What the heck are these??-rough-in2.jpg   Basement Rough-in; What the heck are these??-rough-in3.jpg   Basement Rough-in; What the heck are these??-rough-in4.jpg
ccleme11 is offline   Reply With Quote
Old 03-20-2013, 01:11 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 684
These are my gueses:
3" is the toilet
2" is shower- confirm by removing the cap and inspect for a trap below the slab
2" toilet vent on the left
1.5" shower vent in the center.
Future lav can be piped into the toilet vent.
A toilet requires minimum 15" clearance from side wall/cabinet to center of toilet. Center of flange should be 12" from finished wall surface
The other requirements are probably determined by your local bldg dept. Where are you located?
Old 03-20-2013, 01:18 PM   #3
Rewards Points: 31
I am in Parker, Colorado. Is there any way that i can get away with no having to change any of the locations?
Old 03-20-2013, 01:39 PM   #4
Plumber
Rewards Points: 684
I don't understand what you're asking or what needs to be changed and why
Old 03-20-2013, 01:45 PM   #5
Rewards Points: 31
I guess what i am asking is do i have to change the locations of these or should they be in the right spot already?
Old 03-20-2013, 02:26 PM   #6
It depends if you want to move the toilet or sink or shower.
If it was for myself I would just leave it where it is or you might get into a mess with lot of jack hammering.
You should be able to obtain your local building codes from your local home owners association or city hall.
wrcato is offline   Reply With Quote
Old 03-20-2013, 03:17 PM   #7
Rewards Points: 31
I would like to have the shower on the right, Toilet in the center, and Sink on the left. Would this work with the current layout?
Old 03-20-2013, 03:35 PM   #8
If the two inch abs pipe on the right of the toilet is actually a shower drain then yes that layout would work. Just because that is how it looks from the pics that it was laid out.
If this is not the case you would have to do some jack hammering and repiping and venting.
Old 03-25-2013, 12:40 PM   #9
Rewards Points: 31
After taking the lower half of the insulation out there were notes left on the wall!
From left to right:
1- Toilet Vent
2- Toilet; 3" drain - 18" off foundation wall
3- ?
4- Shower; 2" drain
5- 3"stak
My question now is could i just tie into the vent on the left for the sink?
Tags
basement bathroom , basement design , bathroom , bathroom designer
Rough in for Basement TBolt Plumbing 8 12-13-2011 05:56 PM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 05:53 PM
Basement wall issues. Need rough idead of fix. meltdowndave Building & Construction 6 10-03-2009 11:24 AM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
Best way to clean rough basement concrete floor Red Squirrel Flooring 3 09-21-2009 06:47 AM
