Basement Rough In Plumbing - Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2013, 05:37 PM   #1
Rewards Points: 12
We got our basement bathroom roughed in when we built our house, however after the plumbers had laid out the plumbing but before the concrete was laid we asked the builder to reconfigure the bathroom layout, which meant the plumbers had to move some of the drain lines. My concern is that the shower drain is now to far from the vent. The shower drain runs into the main bathroom drain line and wet vented out through the lavatory vent. The distance from the shower drain to the 3 inch drain that is shared with the toilet, and sink is about 6 feet and then another 6 feet from that intersection back to the vent stack. The shower drain is 2 inch. Does this meet code for the venting of the shower?
Thanks.
jdm127 is offline   Reply With Quote
Old 04-26-2013, 08:37 AM   #2
Rewards Points: 672
A picture would help.
B
Beepster is offline   Reply With Quote
Old 04-26-2013, 01:17 PM   #3
Rewards Points: 1,956
If the shower drain is wet vented via the lavatory drain there is no distance limits on the wet vent itself. The distance limit is from where your shower ties into the wet vent to it's trap. 8 foot is the number with a 2 inch drain common for showers. 6 foot for 1 1/2 inch drain.
Ghostmaker is online now   Reply With Quote
The Following User Says Thank You to Ghostmaker For This Useful Post:
jdm127 (04-26-2013)
Old 04-26-2013, 02:59 PM   #4
Rewards Points: 12
Smile
Thanks, it looks like I am safe then. I thought it was from where the vent went vertical. Once again thanks for the help.
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Plumbing project and venting benleef Plumbing 11 08-10-2012 08:56 PM
new basement plumbing karenfazeng Plumbing 1 07-02-2012 11:35 AM
Venting of basement plumbing fixtures david.plymouth Plumbing 3 01-18-2010 05:46 PM
Basement bath plumbing rough in allowing ground water to enter VooDu Plumbing 1 01-07-2010 01:09 PM
