Basement Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2010, 04:19 PM   #1
basement problems
there is water coming up from the floor through the cracks of my basement and when i do landury and theres water coming through the sewer of my basement when it rains. i just wanted to know why is this happening what i can do
dola is offline   Reply With Quote
Old 10-03-2010, 09:08 PM   #2
Rewards Points: 1,446
Start by going around the outside of the house to see if water is collecting on the ground at or near the house. If so you need to fix that, possibly involving regrading the land.
Do you already have a sump pump?
There may also be the problem of the ground being too saturated with water around your house, that is referred to as the water table being too high relative to your house and basement. Additional or other fixes are quite expensive.
Old 10-04-2010, 11:50 AM   #3
Owner
LateralConcepts's Avatar
A combination of problems is occuring. First off, it sounds as though you have a problem with proper drainage of rain and groundwater around the perimeter of your home and foundation. Secondly, your main sewer line from the house to the street is probably made of clay tile, or Orangeburg (Bituminous Fiber). It's not water tight because of cracks, breaks, root-intrusions, offset joints, etc. In which case you're not only having problems with inflow and infiltration during times of heavy rain, but you're also contaminating the ground with untreated waste water. Both problems will require excavation, and appropriate professional help to remedy.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 10-04-2010, 02:04 PM   #4
steveel's Avatar
What lateral said;
IMO, I would first get the drain lines repaired and then do everything that can be done at the surface outside to make water go away from the house. Gutters, runouts, grading, possibly removing vegetation. That's plenty for this fall before winter. Then you can see where you're at.
steveel is offline   Reply With Quote
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
Leaky Basement Advice JRMN Plumbing 6 12-18-2009 06:45 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 05:29 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
