Basement Plumbing Rough-in - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2009, 11:33 PM   #1
basement plumbing rough-in
hi,
my bathroom in my basement is roughed in with plumbing. there are three pipes. one that is obviously for the toilet, one that sticks about 14 inches out of the concrete floor, and then one that runs vertical along the wall of the concrete to the left of the toilet. this pipe that runs along the wall and down into the concrete also looks as if it is vented as the pvc also goes up and into the i-joist. my question is which pipe is for what?
the tall pipe sticking out about 14 inches is for the shower right?
the one that is in the wall and drains down and vents up is for the sink right?
why doesn't the sink just go down like the shower drain?
does it matter which pipe the sink or shower drain into?
also, i replaced my sink and faucet in my kitchen with a sink that only has one drain hole. to get rid of the other drain i simply blocked the old drain's plubming by wrapping the pvc drain pipe with plumbers putty and putting a rubber plug in it. i capped it just above the p-trap so the p-trap is still there think that is ok?
thanks,
phospher is offline   Reply With Quote
Old 03-20-2009, 07:38 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Basement - The toilet pipe should be 3" or 4", a shower pipe should be 2" and the wall (sink) pipe should be 1.5".
A toilet has a built-in trap. The shower pipe sticking up out of the floor should have a trap down in the floor and be vented after the trap, probably to the toilet stack. A sink will have a trap installed under the sink.
Kitchen - Your old kitchen sink should have had only one trap with both sides flowing to it and then on to the drain line. I don't understand why you have a trap left over. How did you trap and connect the new sink?
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-20-2009, 07:44 AM   #3
Registered User
Termite's Avatar
Pictures are worth a thousand words!
Old 03-20-2009, 08:26 AM   #4
pictures
each drain had a p-trap. here is a photo.
basement plumbing rough-in-img_3418.jpg   basement plumbing rough-in-img_3419.jpg
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 08:30 AM
Basement Plumbing Rough In Help bdborch Plumbing 1 06-24-2008 02:28 PM
Rough plumbing in basement (PIC) BrntWS6 Plumbing 4 02-26-2008 06:30 PM
How to get a rough quote on a basement?? cloudkicker101 Building & Construction 4 04-18-2006 11:48 AM
