Basement Plumbing Critique - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2010, 04:00 PM   #1
Rewards Points: 135
basement plumbing critique
hello, im in toronto canada and was wondering if my plumbing layout is correct? the toilet is 10 feet from the drain. thanks
this is a bungalow.
christoff is offline   Reply With Quote
Old 05-20-2010, 07:30 PM   #2
Leak Master
Might be worthwhile to see if a wet vent system can be used. As best I can tell from your drawing, things seem ok. The most important part is, if you are required to pull permits.
O'Leaky is offline   Reply With Quote
Old 05-22-2010, 09:25 AM   #3
Handyman
Rewards Points: 512
Maybe its just me but seems a little overkill. You should be able to run a 2" pipe from the stack and elbow it towards the 3" drain, then use 'Y' connectors to attach drainage for the shower and sink. (instead of running 3 vent stacks)
Also, you may want to check to see how far away the toilet drain is from a 3" stack. If its a bungalow you probably are pretty close to one.
canadaclub is offline   Reply With Quote
Old 05-23-2010, 07:13 AM   #4
Rewards Points: 135
thanks for the info, i have since revamped my drawings only to find that i can't go any further than 10 feet from the drain and i have about 11, so back to the drawing board
Basement shower plumbing question. medicmike Plumbing 5 01-28-2012 04:40 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Darkroom plumbing critique? pesphoto Plumbing 14 10-07-2008 07:46 PM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 10:26 AM
Plumbing in the basement? iGotNoTime Plumbing 7 11-07-2006 01:24 PM
