Basement Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2011, 02:36 PM   #1
Basement plumbing
Hey there, looking for some advice on a couple things as I plan out a big basement finishing project. So, far just searching this site has already helped a ton! I'm just north of Indy.
The house is only 2-3 years old and has a rough in for a full bathroom along with an ejector pit and sump pump. The vent for the ejector comes up from the pit and makes a "T" with one side heading to the outside vent, the other towards the bathroom. I have read that it is preffered to have the ejector not share a vent, but I would assume since it is in the bathroom are, they intended for it to be shared with the sink vent. The toilet and shower are plumbed but there is no piping for a vent for either of those. The shower drain is 6' to 7' from the sink. I've attached an image with notes of the layout.
So, Question #1 - Am I good to go with venting the sink to the ejector pit vent and not having dedicated vents for the toilet or shower in this setup?
Also, we would like to add a laundry area and kitchen area off to the right as you are facing the bathroom area. (The view in the picture) about 15' in from the corner the shower is on. For that...
Question #2 - Can I tie both the laundry and kitchen drains back into the 2" drain in the bathroom. I believe I have enough room for the proper slope...
Question #3 - Should I run that vent PVC all the way around as well and use that, or install AAVs for the laundry and sink. (my house has an aav already in the main kitchen, so they are allowed in my area)
Thanks for any wisdom on this! As a side note, I don't need permits for any of this. I called and checked and in Westfield, IN when the house was built they already approved the basement as part of the livable house (it has egress, fire alarms, etc) so it is up to me to make sure I do it right and safe. (or hire someone!!
Thanks! Tim
TimMauriello is offline   Reply With Quote
Old 10-24-2011, 11:42 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 664
I'll answer according to code I use:
1. yes, if it is 2" (I'm assuming the toilet vent is the lav drain) Is there a vent riser near the shower?
2. That is a large fixture load on the toilet vent. I couldn't do it per my code.
3. Sounds like AAV's are legal. I'd do it.
Hope that helps.
Old 10-26-2011, 05:45 PM   #3
Hope that helps.
Thanks for the insights, to answer your questions...
There is not a vent riser for the shower. I can only assume they figured that the lav drain/vent is the vent for the system. Its about 7' from the lav to the shower.
I can use an AAV for the new kitchen and laundry area.
So, to be clear, would adding a laundry and kitchen drain connect and drain into the 2" lav drain be OK?
Thanks,
Old 10-26-2011, 08:18 PM   #4
Plumber
Rewards Points: 664
I suppose you could put the sink and laundry on the 2" toilet vent. It maxes out the wet vent code that I work with, but I'm not in IN. so I can't say for sure. Will it drain? Yes. Will your toilet and shower function properly when the those fixtures are draining into the toilet vent? Don't know for sure.
Basement shower plumbing question. medicmike Plumbing 5 01-28-2012 04:40 PM
Basement Suite Plumbing krenkem Plumbing 0 05-25-2011 08:47 PM
How to design plumbing drainage in basement sonicsmooth Plumbing 0 02-02-2011 01:55 AM
Laying out plumbing for basement finishing - pictures included hyunelan2 Plumbing 7 10-20-2010 07:22 PM
Basement Plumbing Rough-in drawing greenyone Plumbing 3 06-09-2010 08:45 AM
