Old 01-06-2013, 12:39 AM   #1
Basement island water supply lines
Wondering what is the best way to run water supply lines to a wet bar in a basement island?
jdm127 is offline   Reply With Quote
Old 01-06-2013, 12:42 AM   #2
Is the basemant already finished out or is the veiling open?
Reason I ask is if there's some way you could built in some fancy looking coloum sitting on the counter top you could run your supplys and power inside of it.
That's a whole lot easyer then busting out concrete.
Old 01-06-2013, 12:49 AM   #3
We are just in the framing stage, but no work has been done on the island wet bar and the ceiling is still open. Is there any code against putting water supply lines and electrical lines down a shared column?
Old 01-06-2013, 07:55 AM   #4
Roofmaster
Nahh just go ahead and do it. You could put a column on each end for balance, power through one, and water through the other. Then along comes junior and drives a nail into column B and well, you know the rest of the story
What about drainage?
" A lot of men build things, and a lot of things fall down "
Old 01-06-2013, 10:20 AM   #5
Drainage already in place.
Best way to add supply lines? HammerinScrews Plumbing 7 08-14-2012 12:19 AM
LP gas supply lines cleaning Doug Saby Appliances 3 11-14-2010 08:07 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Braided water supply lines - joining two KLR Plumbing 8 06-02-2009 04:53 PM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 05:23 PM
