Basement Floor Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2009, 01:43 AM   #1
Basement Floor Leak
I have water seeping through the basement floor and its not near any wall and there is no indication of where it can be coming from.
Has anybody experienced this?
Right now I asked everybody not to use the washroom in the basement, so I can monitor the problem. I have checked every in the bathroom and can find anything wrong.
What is the chances of rain water seeping throught the basement floor, when the nearest wall is 8 feet from the wet spot?
Or can it be a drainage line under the floor?
Some input would be appreciated.
cheers
Celtic DIY is offline   Reply With Quote
Old 08-02-2009, 07:05 AM   #2
Water is peculiar stuff, it can appear in spots far removed from the actual source. But it could be a spring, it could be a leak in a pipe(any underground plumbing in that area?). You could have the water tested which might help pinpoint the problem. City water will have chlorine, sewer leak will be high in bacteria, rain water will have none of that.
Old 08-04-2009, 05:44 PM   #3
i can't offer any suggestions but just like to asy "great diagnnosis ideas JUSTBILL"
ropers is offline   Reply With Quote
Old 08-04-2009, 09:05 PM   #4
Basement Floor Leak update
Just an update and thanks for your responses.
The basement washroom has not been used since the cleaning has taken place and the carpet is drying up slowly and there is no water to be vaccumed up.
I spoke to a friend who is a licenced plumber and said "water is very lazy" he told me to stop using the washroom for now, he is hoping it is just a spud gasket on the toilet, told me to continue monitoring till the end of the week, he'll be over to have a look at the end of the week and he told me not to replace the gasket until we are sure it is not something else.
I'll keep you posted.
Old 08-04-2009, 09:37 PM   #5
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Funny....I've become very popular and have made alot of "friends" over the past 20+ years as a licensed plumber....wonder why. lmao
Seriously though, its good that you've got a friend in the biz. Good advice he gave you there. Keep us posted and good luck.
JDC is offline   Reply With Quote
Old 08-04-2009, 10:32 PM   #6
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
water
Water always finds the weakest link on anything. Be it wood, cement or even steel. Put food coloring in the water and you will find the problem.
lonsplumbing is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 04:29 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
