Basement Floor Drain Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-02-2013, 10:45 PM   #1
Rewards Points: 14
Not sure if this belongs in the plumbing section, but here goes...
My house is an older property in the country with a sump pit that kicks out water to the ditch. The floor drains are old clay pipe, without a trap on the end and there is a strong musty stench that comes from the drains constantly.
I've tried to keep the water level in the sump pit high enough to keep the drains wet, as I believe the smell is coming from the dry pipe. However it is impossible to keep a water trap seal without flooding the basement.
Any idea how to fix this or improve the smell????
ldogg is offline   Reply With Quote
Old 07-03-2013, 08:26 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by ldogg View Post
I've tried to keep the water level in the sump pit high enough to keep the drains wet...
Allow/encourage it all to dry out
Old 07-03-2013, 05:32 PM   #3
Rewards Points: 1,866
Get your basement professionally water proofed.
Sewer smell in basement (with pictures) cne24 Plumbing 4 02-11-2013 06:37 PM
Basement moisture/humidity issues amason2308 Remodeling 2 09-12-2012 08:27 AM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
basement flooring suggestions? jeffro83 Flooring 2 05-14-2011 12:58 PM
Gas smell from new basement shower ThunderCAT Plumbing 3 12-14-2009 11:09 PM
