Basement Floor Drain Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2013, 04:39 PM   #1
Basement floor drain question
The main floor drain in my basement is in the middle of the laundry room. Every time I run the washing machine, soap foam comes up from the floor drain. It's not a lot and its not water flooding, just suds.
I'm wondering if anyone knows why this is happening? And, how it can be fixed? Thanks
Mikeham is offline   Reply With Quote
Old 03-10-2013, 05:16 PM   #2
Roofmaster
Rewards Points: 2,210
I would put a test plug in it and take it out when you want to mop the floor.
Old 03-10-2013, 05:24 PM   #3
Rewards Points: 14,306
Using to much soap, slow running drain.
That drains there for a reason I would not plug it up.
Old 03-10-2013, 07:24 PM   #4
Rewards Points: 2,106
House drain outside may be starting to block. Suggest you call in the local plumber and have him snake your main drain from house to street.
Other thing that might be wrong is your not using HD detergent in one of them fancy new washers or to much detergant read the label on the bottle to determine quantity.
Ghostmaker is online now   Reply With Quote
Question on basement wall/foundation height iub98 Building & Construction 6 07-15-2012 10:15 PM
Basement bath framing question. oba97 Building & Construction 2 02-02-2012 12:58 PM
Unique basement insulation question gunner74 Insulation 3 12-01-2011 08:11 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
Basement sloping and subfloor install - question globus999 Building & Construction 2 06-17-2010 01:17 PM
