Basement Floor Drain Causing Me Anxiety - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2009, 01:33 PM   #1
Basement floor drain causing me anxiety
Last night we had some heavy rains come through. I was in the basement and noticed the water level seen through the floor drain was higher than usual. I freaked out and grabbed some rags and sat there watching the drain to see if it was going to get any higher... it didn't. It eventually went back down to a lower level.
My house was built in 1958, I assume this drain has a trap and then connects to the sewer line and heads out to the street. I figured the only way the water level could rise would be if the sewer line was backing up. To test this theory when the level was high I went upstairs and flushed the toilet a couple of times. I ran downstairs afterwards to see the response in water level in the floor drain. It didn't change at all. Does that make sense?
I've heard some basement floor drains just dump into the soil under the floor. If this was true the rising water would coincide with the groud table rising... I don't know
I want to install a floor drain float plug but i can't find any that fit my drain. It looks like I have a 2 3/4" floor drain pipe and all I can find online is 2" and 3".
Any help is much appreciated!!
tondar is offline   Reply With Quote
Old 06-21-2009, 09:06 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,.... Sounds like you're frettin' over Nothin'.....
It's been working Just Fine for 50 Years,... What makes you think it won't continue to do so,..??
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 05:29 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
