Basement Floor Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2012, 02:56 PM   #1
Basement floor drain
There is a 2-3" hole in basement floor that has water in it with a perforated plastic cover over it. It must have backed up a bit as there is a dirty stain on the floor with a water stain. About 3' from that is a sewer drain cover that looks capped off. So should i be alarmed about the water and call a plumber or call the township if it is the sewer?
New build house that is 7 years old and never noticed this before today. Any advice would be great
cjlivinlife is offline   Reply With Quote
Old 12-16-2012, 04:05 PM   #2
Rewards Points: 1,294
storm water drains are not usually connected to sanitary sewers. Not sure if your floor drain would be or not. It isn't by chance a stubout for a basement toilet?
danpik is offline   Reply With Quote
Old 12-16-2012, 04:22 PM   #3
No stubout. I can look down in it and it is a plastic pvc pipe and there is some water down 4 inches or so. Just didnt know what would have caused it to backup a little. Would that be the responsibility of the township if it is the storm sewer?
Old 12-17-2012, 12:17 AM   #4
Rewards Points: 1,092
have u run a snake in it to see if you can get it to drain; same for the rest of the line below it? how long has it been filled?
Old 12-18-2012, 03:13 PM   #5
No have not run a snake yet. Had township come out and they said no blockage from street to house. It has not happened since last Thurs.
Old 12-18-2012, 04:29 PM   #6
hmm. another FM deal, huh? solved.
Basement sewer smell jturk1000 Plumbing 1 09-20-2011 12:59 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
