Basement Floor Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2012, 09:26 PM   #1
Basement floor drain
1973 home floor drain flood with clean water
Jimmy65 is offline   Reply With Quote
Old 02-07-2012, 09:34 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
What?
Little more info please.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-07-2012, 10:15 PM   #3
Someone has pluged the drain going down but there is a pipe hole entering the drain above the bottom main hole. Clean looking water has filled the drain bowl. The drain bowl has mud in it
Old 02-07-2012, 10:54 PM   #4
Rewards Points: 13,242
No pictures, no idea what you mean by bowl. Bowl in a toilet, Tupperware bowl, soup bowl?
Going to have to be more clear.
Old 02-08-2012, 08:47 AM   #5
Rewards Points: 1,440
Do you have a perimeter subsurface drain system and sump pump in the basement?
Some folks recommend putting a check valve in the floor drain, but I don't think that works well because dirt can hold the check valve ajar.
Old 02-08-2012, 09:43 AM   #6
Rewards Points: 150
My head hurts
psilva8 is offline   Reply With Quote
Basement sewer smell jturk1000 Plumbing 1 09-20-2011 01:59 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
