Basement Fixtures - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2013, 04:37 PM   #1
basement fixtures
I have a toilet and basement utility sink and both do not appear to be vented. Both are within 3 feet of the main stack. Is this normal for these fixtures not to be vented?
mikem201 is offline   Reply With Quote
Old 03-07-2013, 05:01 PM   #2
DIY staff
Rewards Points: 7,174
With in 5 feet of a vent is okay----however there may be a violation of todays code --depending on what is draining into the stack----
Post a picture or two and the age of the house if you want better answers.
Old 03-07-2013, 05:04 PM   #3
The house is 50 years old. Its within 5 feet but the fixtures from the first floor would be wet venting and I was told you can only wet vent fixtures if there on the same floor.
Old 03-07-2013, 05:28 PM   #4
Rewards Points: 1,948
Today it is no good... But 15 years ago it was. Then some bright young code writer figured out that this arrangement can cause siphoning of the basement fixtures... Plumbing is for ever evolving as we learn about issues.
Old 03-07-2013, 06:25 PM   #5
So, your saying those basement fixtures should of been re-vented above the first floor fixtures?
Old 03-07-2013, 06:42 PM   #6
DIY staff
Are you having trouble now or are you rebuilding that room and wondering about bringing it up to todays code?
Old 03-07-2013, 07:23 PM   #7
Just curious. Am I write about my last statement about the re-venting? Another quick question...when you have a fixture that needs it own separate vent and its to difficult to re-vent it you can run it out of the roof. My question is can just the vent part of the fixture be run through the roof or do you have to make it a whole new waste-vent stack extending from roof to basement?
Old 03-07-2013, 09:29 PM   #8
DIY staff
If you want to run new vents up into your attic--they may join the existing roof vent up there---a separate roof vent is seldom required---
Your existing basement plumbing may have met code when it was installed----
Does it work well now or is it acting up?
unfinished basement comfort tls1 HVAC 44 09-16-2012 10:44 AM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
