Basement Drainage - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2010, 11:58 AM   #1
basement drainage
have problem with water coming into my basement, house is 1972 house is on corner and in slope from all the sourounding houses , water keeps coming in, help
Moran0845 is offline   Reply With Quote
Old 11-14-2010, 10:40 PM   #2
Rewards Points: 1,452
First step, stop water from accumulating around the foundation.
Old 11-15-2010, 05:03 AM   #3
Homerepairguy's Avatar
Rewards Points: 990
+1. Moran, do you have rain gutters?
Homerepairguy is offline   Reply With Quote
Old 11-15-2010, 03:35 PM   #4
Rewards Points: 150
LOL. What a Moran!
As other stated- first step is to keep water away from your foundations- make sure the ground slopes down away from your house. If that doesn't help, things get a little pricey. Also, does this only happen when it rains or all the time?
gbwillner is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Info/advice needed for basement leak 60 Yr old House pkovo General DIY Discussions 6 01-15-2009 11:40 PM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 02:35 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
