Basement Drain: No P Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-20-2013, 08:11 AM   #1
Basement drain: No P trap
When we moved into our home ~2 years ago, I capped off two basement floor drains that lack a P-trap. I can look straight down the drain about 8-10 inches to where it meets the pipe that leads to our stack. Our house is about 60 years old and these drains were part of the original construction.
My solution for the past two years was simply to cap these. However our basement just took ~4 inches of rain water after a gutter downspout disconnected in a storm and discharged directly into a window well. I would have had a fraction of the water damage had these drains been open.
I'm almost certain the answer is no but I'm wondering if there are any products on the market that would allow me to restore the drains without tearing up the concrete floor? (i.e. a drain with some sort of one-way gasket that allows water in but not gas out)
bdgray is offline   Reply With Quote
Old 04-20-2013, 09:18 AM   #2
RETIRED MASTER PLUMBER,
JERRYMAC's Avatar
Rewards Points: 30
Check out these type of drain blockers
JERRYMAC is offline   Reply With Quote
Old 04-20-2013, 04:32 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Are you sure the floor drains have no drains. Back in the day, they used to install whole house traps or in-line traps for that type install.
Coastal South Carolina
Tags
p trap , sewer gas
Plumbing DIY basement drain oops ddguy Plumbing 14 05-20-2012 07:11 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
Basement Floor Drain & Sewer Gas 1914 Home Plumbing 4 09-26-2009 04:46 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
