Old 04-05-2012, 02:53 PM   #1
Basement drain line question
Ok, There are actually two questions going to be asked here, but they deal with the same area in the basement. See the picture of the area for reference:
1) The first question is in regards to the red outline. This is a galvanized drain line that is in the basement. It has one capped T visible in the picture. The upper part runs up to the ceiling height, and the goes 15 feet perpendicular to the wall towards the center of the house. At that point, there is a 90 towards where the kitchen is, but it is capped off with a plug at that 90. Basically, it is no longer in use. What I would like to do is remove as much of it as I can up to the first 3 -4 feet coming out of the floor. I would like to then use that to drain my washer into if it still drains correctly.
A) Would this be possibly assuming it still drained correctly?
B) How would I go about removing the pipe if I cannot get it turned with a wrench? I've tried it twice and none of the connections move.
C) Also, if I do remove it, then can't get it to drain, how do I cap it off?
D) Will I need a trap if it is being used for the washer?
E) If so, how to I connect PVC to the Galvanized if there are no threads?
2) My second question deals with the drain in the floor marked in blue. It appears to be a Bell trap drain with a bypass. The cover for the bell trap was long gone when I got the house. After looking at it more, I see that the center part of the drain is filled with dirt and rocks it looks like. The drain itself seems to actually drain out the bypass which heads in the direction of the arrow.
A) Can I get a replacement cover for this? it is 7.5 inched across.
B) Do these normally drain in the direction of the bypass? I want to try and clear the debris from the center hole and want to make sure it doesn't go in a different direction.
That's it for the questions at the moment.
jimmyfloyd is offline   Reply With Quote
Old 04-05-2012, 03:06 PM   #2
call me E
TheEplumber's Avatar
Consider this:
A washer requires a 2" min. pipe for drainage
Your line may drain to a dry well which is probably abandoned (why is the pipe not in use?)
To remove the pipe, cut it into manageable lengths with a sawzall. You can cap it with a rubber gem cap.
The "by-pass" at the floor drain is actually a clean out. Its supposed to be plugged.
it's used to rod out the drain line. Clean the debris out of the trap to make it drain properly and re install the plug. for a grate- you may have to fabricate one.
Old 04-05-2012, 04:52 PM   #3
Would using a Laundry tub sink to drain the Washer into work if the pipe is only 1.5" in diameter rather than 2"?
Old 04-05-2012, 08:12 PM   #4
call me E
It should be 2" as well but I've seen lots of them on 1.5"
Cut the pipe off, stick a garden hose down it and see if it drains. If not, cap it with a gem cap and find an alternate plan.
Don't forget, you'll need to vent whatever fixture you put there. Perhaps an auto vent if allowed by your code.
Old 04-05-2012, 09:49 PM   #5
It will probably work okay. It depends on whether the laundry tub is big enough to hold the water pumped out of the washing machine until the water can go (more slowly) down the 1.5" drain pipe.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Drain line plugged on air handler unit - need advice spta97 HVAC 19 07-26-2011 08:50 PM
Adding drain line in basement floor - size and trap? theedudenator Plumbing 0 07-11-2011 10:22 PM
Question regarding floor drain and sump pump combo vetting Plumbing 9 07-29-2010 02:10 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
Basement floor drain causing me anxiety tondar Plumbing 1 06-21-2009 09:06 AM
