Basement Drain Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2012, 10:03 AM   #16
Hi guys just wanted to update what I did with this pipe.
I went to home depot and spent 1/2 hour looking at all the fittings to see what I could try to rig up before trying to open the floor.
I found this flange fitting that I could pass the pipe through and it had the little flange that I could glue to the reducer if I could cut the reduecer flat and open up the reducer hole
I didn't take pics of opening up but this is what I came up with. Its been 2 weeks and so far so good...you can see how the floor has dried up.
thanks for the help
basement drain leaking-img_0042-1-.jpg   basement drain leaking-img_0043-1-.jpg
pete4 is offline   Reply With Quote
Old 01-28-2012, 11:14 AM   #17
Rewards Points: 6,652
Good job on it. At least you did not have to bust up the slab in that area.
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 06:42 AM
Leaking from first floor to basement Deanm Plumbing 7 07-21-2010 06:18 PM
Basement Leaking EWen Building & Construction 6 07-16-2010 07:45 PM
Washing machine in basement drain pinkertonpv Plumbing 7 05-13-2010 08:58 PM
basement still leaking AFTER doing tile/gravel drain annie68164 Building & Construction 2 03-12-2010 08:22 AM
