#1 |
basement drain leaking
Hey there everyone
I have this drain coming from the kitchen on the upper floor and it stated to leak right around the circled area. I put some general purpose stuff that is supposed to stop leaks on everything all around there...worked great but now after a couple of months it has started to leak again. I'm handy have lots of tools but have never worked on plumbing so I have no clue what to do. What can I do to fix this for good. Thank you |
#2 |
retired elect/hvac/plumb
Is that a reducer its tied into?
| The Following User Says Thank You to plummen For This Useful Post: | pete4 (01-02-2012) |
#3 |
Average Joe/ex-Navy IC3
That is what it looks like to me.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
| The Following User Says Thank You to gregzoll For This Useful Post: | pete4 (01-02-2012) |
#4 |
MarginallyQualified
Cutting to the chase...
I think you'll need to break up the concrete around the pipe and dig down a bit until you can get to fresh pipe with a cutting tool. Cut it cleanly. At that point you can set whatever new fittings are needed to transition between whatever it is you have in the ground and the pipe that goes up to the kitchen. I'd include a cleanout in that too. hth |
| The Following User Says Thank You to TarheelTerp For This Useful Post: | pete4 (01-02-2012) |
#5 |
I'd also suspect that the drain is starting to back up from a blockage causing the leak to show up.
| The Following User Says Thank You to joecaption For This Useful Post: | pete4 (01-02-2012) |
#6 |
Seeing how there is a reducer on this what is the best way to re-fit this...if I do open up the area around the pipe and cut the reducer off....run a reducer again?
Is there any way to remove the elbow off the rducer and try that before opening the floor.....the leak is right at the elbow and the floor dries up fast when the stop leak stuff was applied and was working. Just checking my options thanks guys |
#7 |
If that is a pipe nipple between the 45 and the reducer you might be able to remove/replace it,my question is how the nipple is connected to the reducer.
Is is threaded into it some how or is it leaded in?
#8 | |
basement drain leakingQuote:
thanks Last edited by pete4; 01-02-2012 at 12:27 PM. |
#9 |
Looks like steel pipe coming down the wall tied into a cast iron reducer
#10 | |
No this is all abs pipe in the picture, by the way what is this fitting up the pipe. |
| The Following User Says Thank You to pete4 For This Useful Post: | plummen (01-02-2012) |
#11 |
That pipe/fittings looked rough like steel in your first picture!
![]() That makes life much easier,is that reducer and pipe coming through floor abs also or is it cast iron/steel? |
#12 |
thats a clean out plug
#13 | |
sorry about that maybe because of all the crap spewing down it ![]() Everything there is abs pipe |
#14 |
Id take and have that line cabled out first through that cleanout plug.
Then once the area is all dried out id take some clear pvc primer and clean the area around that joint really good and let it dry really good(no water down the pipe) Then id some masking tape and mask off the area directly above and below the joint,then take some of that nasty black abs cement and work it into the joint as good as you can all the way around. Once the glue dries peel the tape back off and run some water down the pipe and look for leaks. Thats not the most ideal way of fixing it,but if you dont want to break up the floor thats the next best thing i can suggest. If that doesnt do if the next option would be a hole in your floor /recip saw and some no-hub couplings
| Display Modes | |
| Basement drain pipe "pit" ground water fix. | alecmcmahon | General Discussion | 13 | 12-01-2010 06:42 AM |
| Leaking from first floor to basement | Deanm | Plumbing | 7 | 07-21-2010 06:18 PM |
| Basement Leaking | EWen | Building & Construction | 6 | 07-16-2010 07:45 PM |
| Washing machine in basement drain | pinkertonpv | Plumbing | 7 | 05-13-2010 08:58 PM |
| basement still leaking AFTER doing tile/gravel drain | annie68164 | Building & Construction | 2 | 03-12-2010 08:22 AM |
