Basement Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2012, 02:28 PM   #1
Basement drain
There is a 2-3" hole in basement floor that has water in it with a perforated plastic cover over it. It must have backed up a bit as there is a dirty stain on the floor with a water stain. About 3' from that is a sewer drain cover that looks capped off. So should i be alarmed about the water and call a plumber or call the township if it is the sewer?
New build house that is 7 years old and never noticed this before today. Any advice would be great
cjlivinlife is offline   Reply With Quote
Old 12-17-2012, 08:29 AM   #2
Rewards Points: 1,442
A drain connected to the sewer (or a septic system) properly has a trap. You are probably seeing the water in the trap.
If you have never put water down that drain, for example when washing the floor, it is possible for a trap to dry out. It is also possible for the sewer to back up into homes emerging first out of floor drains. You can install a back flow preventer if there was none there already but you would have to dig through the conrete floor.
AllanJ is online now   Reply With Quote
Basement floor drain backup mimi123456 Plumbing 6 09-28-2012 12:02 PM
Flooring over basement floor drain BlueBSH Plumbing 8 09-30-2011 10:27 AM
Old Basement Sink Drain - Clay? maybere Plumbing 7 09-27-2011 12:49 PM
Basement vapor barrier over mirror drain eubarch Plumbing 0 09-27-2011 10:57 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
