Basement Bathroom Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2012, 09:19 AM   #1
basement bathroom venting
I was hoping someone could sketch on this photo where they suggest I put vents for this basement bathroom.
i'm not sure if i can get away with one vent, and if so where,
or if I need a vent for each appliance (shower, wc, lav).
thx
https://dl.dropbox.com/u/79088836/pl...2012_00000.pdf
marketbridge is offline   Reply With Quote
Old 09-05-2012, 10:30 AM   #2
if you run a vent up at the lav you will also need one on the drain for
the shower(between the 4 inch and the 2 inch p-trap).
where do you plan to run the vents to?
you can run 3 inch instead of 4 inch.
it looks like there isn't really isn't enough room for everything in this space.
you need a minimum of 900 sq in in a shower(30x30), and that's on the inside.
Old 09-05-2012, 10:40 AM   #3
thx. i am venting up to the roof after tying vents together at basement ceiling.
based on the order of the fixtures, if i only put a vent on the lav and the shower, won't the toilet pull the waste out of the p-trap for the sink when flushing and hence allow gases to travel up the sink drain?
Old 09-05-2012, 11:50 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 670
Your lav will be vented- so no
Are you really planning on putting a tee on it's back for the wc?
Old 09-05-2012, 01:47 PM   #5
does this look OK?
bathroom subfloor (Basement) BlueBSH Building & Construction 27 12-02-2011 10:10 AM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
Basement Bathroom Rough In snowwhite49 Plumbing 2 05-26-2008 09:11 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
