Basement Bathroom - Vent? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2009, 08:13 PM   #1
Basement bathroom - Vent?
I am in the process of putting in a basement bedroom and bathroom. House is 10 years old and the bathroom was stubbed in. Do I need to run a seperate vent pipe for this, or is this what is considered a "wet-vented" setup? There is no existing vent to tie into in the floor above, so I would have to run a pipe through a wall above and into the attic and up through the roof; would be a huge pain. See pics for clarification.
There are two existing vents through the roof, one from the upstairs bathroom, and one out of the upstairs laundry.
House is on a holding tank if that matters at all.
Pic of the setup:
dogshooter is offline   Reply With Quote
Old 12-28-2009, 08:14 PM   #2
2" stub for shower
Old 12-28-2009, 08:16 PM   #3
Notice the floor drain in bottom right corner of pic. This is the drain for the furnace as well. I'm guessing they are all tied together.
Old 12-29-2009, 08:31 PM   #4
Where is the rest of the plumbing tree/waste lines for the other two areas in relation to this area?
Does the "floor drain" have an actual pipe down there or is that just gravel I see?
When you said the "house is on a holding tank", did you mean a septic tank? or an actual holding tank that needs pumping on a regular schedule as you have no septic field?
meboatermike is offline   Reply With Quote
Old 12-30-2009, 06:12 AM   #5
The rest of the plumbing tree is to the right of the floor drain in the pic, behind the furnace (about 4 feet from the floor drain)
Does the "floor drain" have an actual pipe down there or is that just gravel I see? There is a pipe down there, with a grate over the top, normal floor drain.
Its a holding tank....5500 gallons and needs to be pumped about every 3 months or so. The ground here wouldnt "perk" for a conventional septic, so a holding tank it is. Pretty common for our area).
Thanks for the help.
Old 12-30-2009, 09:57 AM   #6
Rewards Points: 1,646
Is the sole plate for your stud wall pressure-treated lumber? If not, you might want to swap it out for pt.
bob22 is offline   Reply With Quote
Old 12-30-2009, 12:16 PM   #7
Yes, definately treated.
Old 12-30-2009, 02:03 PM   #8
Prince George, BC
I, too, have a similar looking setup, but assumed (in my 2 year-old-home) that it all ties in with the venting somewhere. Can anyone else shed light on this topic for us?
MisterPG is offline   Reply With Quote
Old 12-30-2009, 04:59 PM   #9
Jack of all, master nope
I'm no expert here, in fact I am right about the same stage you are. I have been doing quite a bit of reading and from what I can gather it appears, at least in my case, that all the stubs are tied together with no vent pipe anywhere in site. Since your install looks a lot like mine (my floor drain is also stubbed in concrete) you might have the same situation. I'm considering using a Studor vent (http://www.ipscorp.com/studor/minivent) for venting. The web site has lots of good info. I would suggest you take a look. It sure beats running vent pipe out of the roof!
rss021815 is offline   Reply With Quote
Old 12-30-2009, 06:53 PM   #10
I don't think that vent type is accepted in all localities. If this is a permitted installation, you might want to check on this before proceeding.
Old 12-31-2009, 06:58 AM   #11
I checked on the Studor vent with the permit guy in the township I live in...it is acceptable here and sounds like the way to go.
Thanks for the help all...
Old 12-31-2009, 04:04 PM   #12
Cool let us know how it all turns out
Old 12-31-2009, 04:46 PM   #13
DIY staff
Rewards Points: 7,174
There is usually a vent coming off the ejector pit--can you tie into that??
If the pit is not vented you may have an awkward situation--not sure a pit can use a studor vent.
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Basement Bathroom - Sheetrock - Moisture Issues. mikeynpz Building & Construction 2 05-24-2009 10:08 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-22-2006 11:03 PM
