Old 02-03-2014, 10:52 PM   #1
Share |
Basement bathroom--use shower vent for toilet
Planning stages of basement bathroom. Here is a photo of the corner area I have picked out.
-The purple is the existing 4" running in the slab. The location is confirmed via camera.
-That stack on the left of the photo is all vent pipe above the upper 4" San-T. So I can tie into that to vent this bath group.
-The brown is the estimated framing.
-You can see the location I want to put the toilet and lav. The shower will be a 36" x 60" in the corner where the shelving is.
Here is a real photo of the basement.
hammerlane is offline   Reply With Quote
Old 02-03-2014, 10:53 PM   #2
Here is a sketch of how Im thinking of setting the fixtures. Is it OK to use the shower drain as a wet vent for the toilet?
-Purple is existing 4"
-Gray will be 3" for toilet
-Green will be 2" for shower and vent
-Orange will be 1.5" for lav.
The vent locations are shown in red circles.
Old 02-03-2014, 11:23 PM   #3
moderator
TheEplumber's Avatar
I couldn't do that under my code but my venting rules are different. I'm not much help for Ohio work.
Ghost will have the answer for you though
Old 02-03-2014, 11:59 PM   #4
OK...Ive seen a lot of posts recently about basement bathrooms and figured I should get going on mine.
If this setup can't work I can move fixtures around. I'll wait for Ghost.
Old 02-04-2014, 12:09 AM   #5
Guess I could move the toilet over beside the lav and wet vent thru the lav.
Basement bathroom--use shower vent for toilet-vista-1-wc-lav-along-east-wall.jpg
The Following User Says Thank You to hammerlane For This Useful Post:
plummen (02-04-2014)
Old 02-04-2014, 12:57 PM   #6
Doing it myself
Alan's Avatar
Those photos both present the same issue for us westerners.... We have to vent off the top of the pipe, which means hitting a wall before travelling to the fixture. It can't be horizontal below the floor.
You'll have to wait for someone from your area to chime in on this one.
Journeyman Plumber
Old 02-04-2014, 02:48 PM   #7
In this diagram though, the shower and lav definitely have a vertical takeoff on the vents. So in your area it would be the wet vented part for the toilet that is your issue?
I wonder if the laws of physics change from one time zone to another. I figure if it works in one State it should work in the others. Speaking of the way water drains downhill that is.
Old 02-04-2014, 07:03 PM   #8
Either way is fine. What you have marked as a vent has nothing from upper floors draining into it right?
Make sure any tie in to the 4 inch is 40 inches downstream of the stack.
Some things to consider
I would also suggest you make only a single cut into your exiting underground install a clean out on the branch of your y run 3 inch to your water closet with a 3 by 4 inch 90 the 4 inch coming out of the concrete. if you do that you will only need a 2 " vent on the first fixture downstream of the toilet. As long as you do not go beyond 8 foot to your shower trap.
Your inspector will need to see a 5 lb air test on your new piping and the multiple cuts into existing is a problem you do not need... Rethink where your putting the bath and run the entire thing on its own 3 inch line with a clean out so you can ball the new stuff for a test. Use Mission brand transitional couplings plastic to plastic on your main when you cut the Y in.
Not to mention your placing the shower under your duct that will not leave much headroom once you install a ceiling. With concrete saws the ditching is not the problem.
You will also need a fart fan for water vapor...
And don't forget the wet bar for the man cave...
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 02-05-2014, 01:04 AM   #9
100% positive of that.
Will do.
You're saying to put cleanout in the floor along the 3" lateral to the toilet? Also Good call on using the reducing closet bend.
When you say bath do you mean the shower or the entire bath group?
Also I do not understand the statement about using Mission brand transitional couplings. Why would I use a mission coupling? Why not just use PVC cement when securing the new "Y" to the existing 4". The existing 4" in the slab is PVC. Maybe I did not make that point clear.
That duct is 42" out from the wall. May not look it from the photo. After framing out the wall then with a 36" deep shower base, I still will not be under that duct.
A fan will definitely be installed.
Either way Ghost...thanks for the comments. I did get a few ideas from you.
Old 02-05-2014, 10:17 AM   #10
"Also I do not understand the statement about using Mission brand transitional couplings. Why would I use a mission coupling? Why not just use PVC cement when securing the new "Y" to the existing 4". The existing 4" in the slab is PVC. Maybe I did not make that point clear."
If you have two ends of a pipe partially buried in concrete how will you move the pipe to make the joint of the Y your installing? Professionals may glue one side of a Y in but the other side will have a short pipe stubbed out with a mission coupling.
"Rethink where your putting the bath and run the entire thing on its own 3 inch line with a clean out so you can ball the new stuff for a test. Use Mission brand transitional couplings plastic to plastic on your main when you cut the Y in."
With your exiting drain running through where you intend to place the bath it will cause you headaches getting around it. I found it better over the years to just make your tie in and then move the bath out of the area of exiting underground piping.
Old 02-05-2014, 10:32 AM   #11
Gotcha Ghost...Never thought of that issue. Guess thats what experience does for you.
Thanks for the point.
Old 02-05-2014, 11:46 PM   #12
Hey Ghost....I saw an episode of Ask This Old House. When they plumbed in the basement bath, the shower and toilet were both wet vented off the lav. See photo below.
Would this allowed in Ohio? See diagram below. In this diagram, the entire bath is on its own 3" like you mentioned in one of your previous posts. Also in the diagram, the lav is shown venting the shower and toilet.
Basement bathroom--use shower vent for toilet-oldhouse1.jpg   Basement bathroom--use shower vent for toilet-vista-8-all-along-south-wall-all-wet-vent-lav.jpg
Old 02-06-2014, 12:52 AM   #13
According to Ohio Chapter 4101:3-9. Any combination of fixtures within a bathroom group located on the same floor level is permitted to be vented by a horizontal wet vent. So yes you can wet vent the shower and WC off the lav. The wet vent needs to be sized properly depending on the dfu's. Also each wet vented fixture drain shall connect independently to the horizontal wet vent. So in your last picture if you made the lav drain 3" and connected that into your 4" then connect your WC and shower independently into the 3" from the lav I think that would satisfy the requirement. See if ghostmaker agrees.
rosem637 is offline   Reply With Quote
Old 02-06-2014, 04:58 AM   #14
Are you suggesting that the diagram on the right would be a better way to go as compared to the diagram on the left? I did read in the code the statement about "each wet vented fixture drain shall connect independently to the horizontal wet vent". Just wondering if below is the correct interpretation of that??
Old 02-06-2014, 08:55 AM   #15
Doing it myself
Alan's Avatar
Normally they want it sized based on the fixtures being served.... it may be 3" to the shower wye, but I really doubt that they want a 3" drain/vent on the lav. Probably 2" from the shower through the roof.
Wait for an ohioan to confirm.
Journeyman Plumber
Completing a roughed in basement bathroom Bob in St. Louis Plumbing 8 11-18-2011 12:12 PM
Basement bathroom fan vent duct BlueBSH Building & Construction 0 06-25-2010 01:44 PM
Vent stack is on other side of basement... Feretich Plumbing 5 02-12-2010 01:13 AM
bathroom shower in basement along foundation wall jeeper Building & Construction 1 04-16-2009 07:20 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
