Basement Bathroom Smells - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-30-2011, 08:27 PM   #1
Unhappy
My Basement bathroom shower drain smells. But when I flush the toilet the smell comes out of the sink as well and it smells even worse. The upstairs bathroom is fine. Any Ideas?? Thanks
rverb1 is offline   Reply With Quote
Old 08-30-2011, 08:35 PM   #2
DIY staff
Rewards Points: 7,174
The system is not vented correctly----Air must enter the piping in order for the water to go down the drain.
Ever turn a pop bottle upside down? It won't empty very fast--but poke a hole in the jug and it will empty right away---
You are not getting air into the system as you should so the P-traps are getting sucked dry when you flush the toilet.--the system needs air--Mike---
Old 08-30-2011, 08:44 PM   #3
How would I go about solving this problem?
Old 08-30-2011, 08:56 PM   #4
Experienced
Jackofall1's Avatar
3 choices.......
Install proper venting or air admittance valve (search the forum there are many posts on this subject).......
Call a plumber......
Use the upstairs bathroom....
Mark
Old 08-31-2011, 04:58 AM   #5
DIY staff
Jack has it right---How finished is the basement? any way to see the piping and tell if there is a vent pipe near the toilet? It's possible the vent pipe is simply installed wrong or never hooked up at all.
basement bathroom breiding200 Plumbing 4 03-22-2011 10:40 PM
basement bathroom breiding200 Plumbing 2 03-15-2011 03:05 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Basement Bathroom - Sheetrock - Moisture Issues. mikeynpz Building & Construction 2 05-24-2009 10:08 AM
Basement Bathroom Insulatation/VB? mfleming Building & Construction 1 05-06-2009 04:27 PM
