Basement Bathroom Sink Drain Line On A Slight Upwards Slope An Issue? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2010, 02:48 PM   #1
Basement bathroom sink drain line on a slight upwards slope an issue?
Hi,
My basement is in the process of being finished by a hired contractor/company and I'm looking at the drain pipe for the sink and wondering if I should be worried. He tied the sink drain to the rough-in in the basement but it's on a very slight upwards slope. I tried taking a picture to show it... hopefully it's good enough.
dtran is offline   Reply With Quote
Old 01-08-2010, 07:59 PM   #2
The sink will probably work fine forever, but that is definitely an example of poor craftsmanship. I would demand that it be corrected. The horizontal pipe should of had a hanger on it.
liquidplumber is offline   Reply With Quote
Old 01-08-2010, 08:17 PM   #3
Inspector/Instructor
codeone's Avatar
In the plumbing code Draniage piping 2.5" pipe and smaller should have a slope of .25" per foot.
codeone is offline   Reply With Quote
Old 01-08-2010, 08:20 PM   #4
codeone's Avatar
this type of piping should have at least 1 strap to support it as noted.
It requires support every 4' at least and there are none I can see.
Old 01-08-2010, 08:53 PM   #5
Rewards Points: 1,548
Water will persist (or collect) in the section of pipe before the upslope in the same manner as water remains in a trap. The won't be any problem as long as hair or soap residues etc. have not also collected there. A potful of boiling water every so often may help keep it clear.
Old 01-08-2010, 08:57 PM   #6
Thanks guys. That's pretty much what I thought.
BTW, FWIW, maybe it looks longer in the image, but that horizontal piping is only just under 3'.
Old 01-08-2010, 09:20 PM   #7
I know a level isn't the best way to check, but I just put one on the pipe and it's actually level. My housemate is nitpicky and has bugged the contractor several times (for other unrelated small imperfections), so I'll just go out and buy a strap to lift the one side a little giving it a slight slope downwards.
Old 01-10-2010, 05:05 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
tell him to cut the santee out of the stack and install new one lower down to achieve fall in pipe
plummen is offline   Reply With Quote
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 10:32 AM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
Drain for an "Outdoor Kitchen" Sink Rich Plumbing 5 08-26-2006 06:48 AM
