Basement Bathroom Shower Addition Advice - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2010, 09:30 PM   #1
Hello everyone.
I've used this site for a long time because of all the amazing information, but I'm tackling a new project and decided to sign up for a more direct question. I've attached a picture of the bathroom area in the basement of my house, built in 2000. I just got around to taking down the embarassingly poor quality "walls" the original owners installed. On the bottom right corner of the picture, you can see what I assume is a drain in the floor. There is a cap glued on, so I haven't opened it yet. I would like to add a simple shower stall to the corner and I am hoping I can do it with what I have here. I have no idea if there is a P trap under the floor or if the venting is already taken care of. I won't be doing the plumbing job myself (as this is one area I have zero knowledge) but I wanted to at least get a plan together. Does anyone have any advice on this setup?
Also, the first vertical PVC pipe was connected to a pedestal sink, which I removed.
Thanks in advance!
Matt
mattwilliams is offline   Reply With Quote
Old 10-27-2010, 11:06 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 684
I'm guessing at this but what I see in the picture is a WC, a ped lav rough in, a 1.5" vent for shower and capped pipe(2"?) for a shower drain. I don't see any reason why a qualified plumber shouldn't be able to plumb a bathroom there for you.
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
I'm concerned about the moisture build up on the bathroom walls -Any advice? JayBird General DIY Discussions 15 04-07-2009 10:25 AM
Advice on replacing bathroom fixtures t1000 Plumbing 3 07-11-2008 02:42 PM
Shower / Bathroom Install xlr8tn Plumbing 1 01-15-2008 04:08 PM
Bathroom Shower jackco711 Flooring 4 11-14-2006 09:22 AM
