Basement Bathroom Rough-in - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2007, 07:15 PM   #1
basement bathroom rough-in
Hi,
I have four pipes for my basement rough-in plumbing. I'm trying to figure out which one of the 2.5" pipe is the vent pipe. Can someone tell me if I labeled the pipes correctly?
Thanks,
Ronald
ronbo999 is offline   Reply With Quote
Old 02-09-2007, 02:29 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
It sure looks like a vent, maybe for the floor dtain you have there
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-09-2007, 11:11 AM   #3
Should I hook up the vent like this?
Thanks.
Old 02-09-2007, 05:53 PM   #4
Journeyman Plumber
Are those two pipes at the sump pit connected? Can you post a close up of the pipes by the pit?
Old 02-10-2007, 10:03 AM   #5
Actually there's three pipes. Two in the sump pit and one next to it. The two pipes connected together I think is the vent.
Old 02-10-2007, 10:12 AM   #6
I would say that the pipe on the right (going into the sump) is the vent. Then it ties into the main vent and probably goes under the floor and ties into at least one of the other drain lines (maybe more). The center line from the sump is the actual discharge line. The fitting with the two grey nuts is the check valve (ball type) which prevents water from draining back into the sump.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-10-2007, 10:33 AM   #7
Journeyman Plumber
Tie all the vents together and send them out the roof. Min 2" out the roof.
Old 02-10-2007, 11:56 AM   #8
Can't I just connect to the existing vent line like the 2nd picture I've attached with the drawing?
Thanks.
Ronald
Old 02-10-2007, 12:56 PM   #9
Journeyman Plumber
You will need to check your codes on it, there might be some restrictions.
Old 02-10-2007, 01:22 PM   #10
Old 02-12-2007, 08:57 AM   #11
RippySkippy's Avatar
If the vent from the ejector pit goes into the floor, isn't it possible that that vent will service the other items in the bathroom group? I think majakdragon is headed in the right direction.
My guess is that the items stubbed up all flow into the ejector pit, and they are as well vented back to that pipe. Are you sure the two you have labeled as toilet and shower are right? Most showers only require 2" service. Have you taken the caps off to see if there's a trap under floor? Does your whole house use the ejector pit? If not, you could pour water down each pipe and watch it "down stream", use water colored with food coloring to track it.
You might check with the permitting office the builder or house plumber to see if there's a set of plans hanging around.
Good luck,
Rip
RippySkippy is offline   Reply With Quote
Old 02-15-2007, 12:40 PM   #12
I talked to my builder and he said that the 4-inch pipe is for the shower & toilet. One of the 2 inch pipe is for the sink and the other one is for the vent.
Redmodeling basement bathroom amakarevic Plumbing 5 04-23-2007 09:36 PM
basement bathroom heat ktrehs HVAC 3 03-12-2007 04:23 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
Cellar to rough basement? javamom Remodeling 1 06-27-2006 05:23 PM
How to get a rough quote on a basement?? cloudkicker101 Building & Construction 4 04-18-2006 12:48 PM
