Over the last year I've been finishing off my basement and I've reached the part of the bathroom rough in. I don't plan to finish the bathroom right away but need to frame around it so I can finish the rest of the basement...so I do need to identify the parts and figure out where everything will go.
I've diligently read all related posts but I'm still not 100% sure as to what it all is (I'm a worrier). I'm assuming the large pipe in the floor is the toilet drain and the capped piece about 18 inches off the floor is the drain for a vanity with associated venting. The white pipe to the far left surrounds 2 inch or so PVC and so I'm guessing this is for shower/bathtub...yes? My main question is about the second pipe that runs up from the floor and joins into the T off the vent going to the vanity drain...would this second pipe vent the shower drain or the toilet? Mostly I want to be sure about the pipes in the floor so that I frame the bathroom door in the correct place...
Can you help?
Mallory
Can you help?
Mallory
