Old 03-12-2011, 10:18 PM   #1
advanced newbie
basement bathroom remodel
just starting a basement bathroom remodel. The floor is a slab, the current toilet placement is RIGHT inside the door, There is no place to move the door. Thankfully the door opens out. I believe the toilet drain may be right into the septic. how can I check this and if this is true, is there any way to move the drain that is currently in the floor? Thanks.
janev is offline   Reply With Quote
Old 03-12-2011, 10:33 PM   #2
Super Moderator
Any thing can be done--Post a picture if you can---also is plumbing PVC or cast iron.
Pull the toilet and see which way the pipe goes--there is no P-trap on a toilet line--
Jack hammering the floor and moving things around is done all the time---
We need more facts to offer any suggestions-----Mike---
Old 03-12-2011, 10:41 PM   #3
advanced newbie
Thanks oh'mike. The toilet is out, it's cast iron pipe, it looks like it goes straight down. There is a clean out directly behind the toilet on the other side of the wall. no light right now for photos, i will in the a.m.
Old 03-12-2011, 11:11 PM   #4
Super Moderator
Good,Look for the main vent stack---poke something down the toilet hole--see if you can figure out which way the pipe goes---It probably heads for the clean out or main stack.
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 10:35 PM
Basement bathroom floor n2learning Flooring 5 07-13-2010 12:55 PM
Questions about insulation in basement remodel BillG Remodeling 1 04-27-2010 09:15 AM
Double Bathroom Remodel coreyandnicole Kitchen & Bath Remodeling 1 03-19-2010 10:59 PM
Bathroom Remodel Questions Vikeologist Remodeling 52 12-31-2009 10:13 AM
