Old 08-09-2007, 08:31 AM   #1
Basement bathroom relocation?
Looking to relayout the basement bathroom. Basement has yet to be finished.
I am attempting to move the intended location of the bathroom from the south side of basement to the north side (where it says proposed basement). How can I get rid of or reroute the existing drains/vents located on the south side of the basement? I dont plan on doing this until the winter months but I have no problem cutting up sections of the floor.
tigerbalm2424 is offline   Reply With Quote
Old 08-10-2007, 03:31 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro plumber, just a long-time DIYer.
The main problem that you may run into is the depth of the main drain line that you need to connect the new bathroom line to. There needs to be 1/4" of decline per linear foot toward the existing main line.
Can you talk to the original builder or plumbing sub or owner to find out?
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-10-2007, 06:37 AM   #3
Mike
That was my first thought, but I was unable to track down the contractor/builder/ or owner.
Old 08-10-2007, 01:19 PM   #4
Open up that cleanout near the water main and use a snake to see if that's where your sewer exits the house. It looks like it does because of its location. If so, that's your target area to pick up the 3 or 4" main drain. The main drain line currently travels some route between the cleanout and where your upstairs bathroom drain enters the concrete slab. Cut open a small area immediately next to the cleanout (opposite side of the cleanout from the wall) and dig down to the main (you can follow the cleanout pipe down to the main). Cut a trench from there to your new location.
As far as your old location I would just leave it. You never know what the future holds.
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 10:12 PM
Redmodeling basement bathroom amakarevic Plumbing 5 04-23-2007 09:36 PM
Basement bathroom remodeling amakarevic Building & Construction 2 04-12-2007 08:59 PM
basement bathroom heat ktrehs HVAC 3 03-12-2007 04:23 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
