Basement Bathroom Plumbing Vents - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-21-2013, 03:40 PM   #1
Hello all,
I am new around here. Just curious if anyone could tell me if the following is legal in New York state or at all. We have 1 2" vent venting both toilet and shower. Shower is less than 5' from the 2" vent. The 2" vent is "teed" up from the 3" line that the toilet drains into.
Thanks!
marioluigi is offline   Reply With Quote
Old 08-21-2013, 08:59 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
If iam looking at your drawing correctly and your under the IPC the answer to your question is no.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 08-21-2013, 09:10 PM   #3
What is the correct way to do it? Does each line need a separate vent?
Old 08-21-2013, 09:58 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 682
UPC says no too. But I don't think NY is UPC so I can't advise you except to say I would put the shower on the vertical vent.
The safest way would be to give both fixtures independent vents- cut the shower in down stream of the existing vent
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (08-22-2013)
Old 08-21-2013, 10:13 PM   #5
By cut in down stream you mean cut the main waste line from the stack and feed it in there? Minus the shower is the toilet properly vented? Is the problem there won't be enough air in the lines? What exactly is not to code about it?
New York goes by IPC from what I've learned although specific towns have their own code too. This is town of oyster bay if that helps.
Old 08-22-2013, 06:54 PM   #6
Rewards Points: 582
i know places differ with code requirements ..but plumbing basics stay the same...all plumbing fixtures work better with there own vent and i never seen and inspector fail a plumbing plan that had independant venting...ever ...40yrs and counting...ben sr...vent both fixtures....
Old 08-22-2013, 07:18 PM   #7
Rewards Points: 1,956
I honestly can't make head or tails out of that drawing.
Old 08-22-2013, 07:19 PM   #8
If I'm looking at it correctly where is the hand sink?
The Following User Says Thank You to Ghostmaker For This Useful Post:
ben's plumbing (08-23-2013)
Old 08-22-2013, 08:24 PM   #9
Plumber
Rewards Points: 682
Good question- let's say we wet vent it on the toilet vent later.
I assumed the drawing was a plan view. Never seen a square stack though
Adding a tub/shower to basement bathroom? Latsay Plumbing 34 12-24-2011 12:34 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 07:13 PM
Could use advice regarding plumbing for a basement bathroom raaczb Plumbing 3 01-22-2011 12:22 PM
New basement bathroom vents biggidybankston Plumbing 4 12-10-2009 05:56 PM
basement bathroom (concrete floor drain plumbing) amakarevic Plumbing 4 11-27-2007 05:37 AM
