Old 05-21-2009, 10:24 PM   #1
Basement Bathroom Plumbing & Venting - Need Help!
I enjoy doing projects myself and have recently undertaken a big one. I am finishing my basement. I figured I would start with the bathroom since that involved removing portions of the slab and installing a sewage ejector pump (my main sewer line is 8' above the basement floor). I have already removed the concrete and have the pump where I would like it, but am uncertain exactly how the venting should work. After reading through these forums I understand the basics of what size drain and vent lines are necessary ... I'm just not sure if my plan is best suited for the fixtures I have. I am attaching a very basic drawing with how I am planning on laying out the drain lines and vent lines.
Any suggestions would be GREATLY appreciated! I live in Atlanta, GA, so if anyone has any experience with code in or around the area ... let me know (my calls to the building department have gone unreturned).
Thanks so much!
Basement Bathroom Plumbing & Venting - Need Help!-basement-bathroom-plumbing.jpg
Tbone2009 is offline   Reply With Quote
Old 05-22-2009, 06:36 AM   #2
Remodeling Contractor
The ejector pump should have a separate vent through the roof, not one connected to other fixtures.
Old 05-22-2009, 07:44 AM   #3
Is there any way to avoid running a separate vent for the sewage ejector pump? I live in an older home that poses a lot of challenges for running a separate vent, so if it's avoidable I would definitely want to go that route!
Old 05-22-2009, 07:58 AM   #4
Thanks so much!
I would recommend running 4" pipe to the toilet a 4 by 3 closet flanges slips right into a 4 inch sch 40 pipe. Also your vent for the sewage pump pit should go all the way thru the roof by itself with nothing else tied into it. I have done it the way you have it drawn and it worked fine as long as you go at least 8 inches above the flood rim of the top fixture but it is not up to code.
al's sewer is offline   Reply With Quote
Tags
basement, basement bathroom, plumbing, sewage ejector pump, venting
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
Venting up vs out for bathroom, kitchen pcampbell HVAC 12 11-15-2008 11:02 AM
Want to tile bathroom - raise plumbing? wombosi Plumbing 2 11-13-2008 08:54 PM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 09:30 AM
