Basement Bathroom Pex Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-13-2011, 08:53 AM   #1
Hello,
My name is Joe and this is my first post to the DIY forum. I am in the process of finishing a basement and have come to the bathroom. My house was built in 2006 and all plumbing is rigid copper. For simplicity, I'd like to use Pex to tie into the existing water lines. I have a couple of questions. First, is a basic plumbing question. I need to plumb for a shower, vanity, and toilet. Should I run each of those back to the main 3/4 copper separately or bring one pex line for hot and one for cold and tee off from the pex for each? What is the best way to tee into the copper? I've looked at the quick connects, and I like the idea, but am skeptical since this is not going to be accessible once the drywall goes in. No plans for a drop ceiling. I'm going to drywall everything.
Thanks in advance for any input from the forum.
Joe
binkley is offline   Reply With Quote
Old 09-13-2011, 11:08 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What's the distance to the copper you are going to be connecting to?
I'd say for a guest bath in the basement, i'd run separate 1/2" lines for them if they're within 20 feet or so. 1/2" pex is cheap by the foot, and then you won't need any fittings inbetween.
The best way to tee in to the copper is with a copper tee and the appropriate pex adapter.
Quick connect in a concealed location no matter if our local codes allow them or not is a no-go, ESPECIALLY on new construction.
I only use them on mobile homes where a repair is needed, because I feel that a sharkbite fitting on qest piping is better than the original qest fittings and crimp rings any day.
Journeyman Plumber
Old 09-13-2011, 05:04 PM   #3
It's less than 20 ft for sure. I think you covered all of my concerns. I'd rather not sweat a bunch of fittings, but this route beats the alternative.
Joe
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
Yet More Basement Questions DocWard General DIY Discussions 8 06-29-2011 10:24 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
Basement Bathroom Rough-in questions Bmbeeson Plumbing 16 12-29-2007 01:41 AM
