Old 11-26-2007, 07:36 PM   #1
Question
basement bathroom (concrete floor drain plumbing)
when laying concrete over drain plumbing, e.g. for a tub, toilet, etc., i was wondering if it is customary to box some space around the fixture outlet to allow room for posterior modifications, as patcher can be filled just before installing fixtures.
or should i be sure that everything is calibrated right 100% before pouring ?
Old 11-26-2007, 09:00 PM   #2
ICF Construction
Bathtubs are generally boxed out to allow for drain connection at a later date, all others are pretty much stationary and should not need movement provided you have figured out your layout. Don't forget to wrap at least a 1/2" of foam around any pipes that will be in contact with the concrete.
Chris
Chris Johnson is offline   Reply With Quote
Old 11-26-2007, 10:51 PM   #3
Wink
which foam should i be using ? is that the only extra thing i need to do in this scenario that you can think of ?
thanks,
- a
Old 11-26-2007, 11:38 PM   #4
ICF Construction
I use sill gasket (sill seal) (The foam you put between the bottom plate and the concrete slab) Wrap it around a few times and your ready to go.
Chris
Old 11-27-2007, 06:37 AM   #5
Send a message via AIM to Marlin
Slide the next size larger piece of pipe over your drain line before pouring and remove it once set. This will keep the pipe out of direct contact with the cement and allow you just a little bit of movement if you need it.
Marlin is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Redmodeling basement bathroom amakarevic Plumbing 5 04-23-2007 09:36 PM
Basement bathroom remodeling amakarevic Building & Construction 2 04-12-2007 08:59 PM
Creating new bathroom...plumbing difficulties? AllGoNoShow Plumbing 4 11-15-2006 01:05 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
