#1 |
Basement Bathroom
I am going to put a bathroom in a basement. It will have a shower, toilet and lav. There is a 4" floor drain not to far from the wall where the fixtures are going. Somebody recently tied a washing machine drain line into the floor drain line. I was planning on running a 4" line for the toilet and a 2" line for the shower and sink. Connect the shower and sink into the 4" toilet line with 2-4x2 wye's. There is a vent for the washing machine line and I was going to vent the shower and sink in the wall and then connect to the washing machine vent.
Is this correct?
#2 |
Journeyman Plumber
Basement Bathroom
Where are you at?
Fix it right the first time, so you won't have to fix it a 2nd time. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Basement BathroomLast edited by lambert; 02-02-2007 at 10:27 PM. Reason: added link |
#4 |
Journeyman Plumber
Basement Bathroom
This is how we do it, your code may or maynot be like this, you will need to know your codes, here each fixtures requires a vent for each fixture, one for toilet, shower and lav, then they can all connect to one vent, min vent size for toilet 2"
If your adding, get a permit and have the proper inspections, this way you know it meets code requiremenrs.
#5 |
Basement Bathroom
"Ron the Plumber", you ROCK!
One more question, how would I vent the toilet? |
#6 |
Journeyman Plumber
Basement Bathroom
Vent the toilet in the same wall as the sink and shower will vent into. Vent it on a wye / 45 combo.
#8 |
Journeyman Plumber
Basement Bathroom
3 x 2 wye
#9 |
Basement Bathroom
So the toilet drain should be 3", I was going to use 4".
Just an fyi, the drain line for the washing machine is tying into the floor drain. So can I tie the main that the bathroom fixtures are running in anywhere between where the washing machine is draining and the floor drain? Last edited by lambert; 02-03-2007 at 09:41 PM. |
#10 |
Journeyman Plumber
Basement Bathroom
I can be 3" if you want, or 4" if you desire it to be.
| Display Modes | |
| Drop ceiling in basement bathroom | handyflyer | Remodeling | 23 | 05-26-2009 10:12 PM |
| Redmodeling basement bathroom | amakarevic | Plumbing | 5 | 04-23-2007 09:36 PM |
| Basement bathroom remodeling | amakarevic | Building & Construction | 2 | 04-12-2007 08:59 PM |
| basement bathroom heat | ktrehs | HVAC | 3 | 03-12-2007 04:23 PM |
| Basement Bathroom Tiling Question | KUIPORNG | Flooring | 1 | 07-23-2006 12:03 AM |
