-   -   Basement Bathroom (http://www.diychatroom.com/f7/basement-bathroom-6275/)
lambert 02-02-2007 06:37 PM
Basement Bathroom
I am going to put a bathroom in a basement. It will have a shower, toilet and lav. There is a 4" floor drain not to far from the wall where the fixtures are going. Somebody recently tied a washing machine drain line into the floor drain line. I was planning on running a 4" line for the toilet and a 2" line for the shower and sink. Connect the shower and sink into the 4" toilet line with 2-4x2 wye's. There is a vent for the washing machine line and I was going to vent the shower and sink in the wall and then connect to the washing machine vent.
Is this correct?:eek:
Ron The Plumber 02-02-2007 07:48 PM
Where are you at?
lambert 02-02-2007 08:48 PM
Originally Posted by Ron The Plumber (Post 32222)
Where are you at?
chicago
Here is a drawing: http://www.websitecr.com/images/bathroomlayout.pdf
Ron The Plumber 02-03-2007 03:18 AM
1 Attachment(s)
This is how we do it, your code may or maynot be like this, you will need to know your codes, here each fixtures requires a vent for each fixture, one for toilet, shower and lav, then they can all connect to one vent, min vent size for toilet 2"
If your adding, get a permit and have the proper inspections, this way you know it meets code requiremenrs.
lambert 02-03-2007 04:57 PM
"Ron the Plumber", you ROCK!
One more question, how would I vent the toilet?
Ron The Plumber 02-03-2007 05:24 PM
Vent the toilet in the same wall as the sink and shower will vent into. Vent it on a wye / 45 combo.
lambert 02-03-2007 05:33 PM
4x2 wye?
Ron The Plumber 02-03-2007 07:42 PM
3 x 2 wye
lambert 02-03-2007 08:35 PM
So the toilet drain should be 3", I was going to use 4".
Just an fyi, the drain line for the washing machine is tying into the floor drain. So can I tie the main that the bathroom fixtures are running in anywhere between where the washing machine is draining and the floor drain?
Ron The Plumber 02-03-2007 08:36 PM
I can be 3" if you want, or 4" if you desire it to be.
lambert 02-03-2007 10:23 PM
Thanks Ron, you've been a big help!
