Basement Bathroom... - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2005, 12:39 PM   #1
Basement bathroom...
I am interested in renovating our basement for extra bedrooms and would like to add one or two bathrooms. Because of the way my sewer pipes go out of the house, I was wondering if this is even going to be possible or, if so, if I will need some type of pump system. Perhaps someone can tell me what they think by looking at the pic below.
:confused:
jj1807 is offline   Reply With Quote
Old 11-10-2005, 12:48 PM   #2
rspainhower's Avatar
Your best bet would be to go to http://www.terrylove.com/forums/index.php?
They will have the best specialists to help you.
rspainhower is offline   Reply With Quote
Old 11-10-2005, 09:01 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Also see www.saniflo.com
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-11-2005, 04:03 PM   #4
Rewards Points: 150
I think you'll have to eject any wastewater to a height in excess of the pipe that exits the basement wall.
A local code must require that funky trap/cleanout assembly. I can picture a backup in the street causing your neighbors sewage to bubble out the top that thing. I hope the top is capped off.
pipeguy is offline   Reply With Quote
Old 11-22-2005, 09:26 AM   #5
Rewards Points: 150
How does that water meter work???
The water meter isnt hooked to any pipe on the left side. How does that work? And the copper pipe going up, does it dead end right above the picture line?? If it doesnt you are geting alot of free water. Has to be more than meets the eye in THAT picture.
Isnt that a washing machine drain, the funky elbow cleanout??? Not exactly hoyle but it may work. Maybe this whole deal is on a country septic tank or sumpthen.
I have seen where you can build up a platform(for stool to sit on) to eject sewage into that height line. That is real old with time too.
justdon is offline   Reply With Quote
Old 11-22-2005, 10:24 AM   #6
how much ceiling height do you have? you may be able to build some kind of stringer system-subfloor to get the kind of run you need to do the plumbing without a pump.
kenvest is offline   Reply With Quote
Old 11-22-2005, 10:44 AM   #7
I'm thinking wall hung toilet, (rear discharge), tub, shower, on a platform. > That contraption with the trap looks like something a fha inspector used to make us do back in the 80's. He wanted a drain in the basement or crawler and didn't much care what it looked like or what function it served, or what is was connected to. Like pipe said, you probably want it capped. I hope the trap has not been dry for a bunch of years.HS.
K2eoj is offline   Reply With Quote
Old 11-27-2005, 03:33 AM   #8
747
registered
747's Avatar
Rewards Points: 534
That is the most screwed up thing i have ever seen. Why They would put a cleanout like that on it is beyond me. You need plumguy to look at this picture.
747 is offline   Reply With Quote
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 09:12 PM
Redmodeling basement bathroom amakarevic Plumbing 5 04-23-2007 08:36 PM
Basement bathroom remodeling amakarevic Building & Construction 2 04-12-2007 07:59 PM
basement bathroom heat ktrehs HVAC 3 03-12-2007 03:23 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-22-2006 11:03 PM
