#1 |
Basement Bath Sink / Laundry Vent Smell
I recently installed a bathroom in my basement and used a pump to drain the vanity and washer. Everything works well except after sitting for two days I get a nasty smell when the pump kicks on for the 1st time. I have vented to the outside off of the pump vent fitting with 1.5 inch pvc. The Pump has a 7 foot lift and i have a one way valve on the pump outlet. The vanities both have ptraps on them and the washer dumps into a slop sink and is also traped to the pump. I tried double trapping the sinks and still no luck. Any Suggestions. Thanks
#2 |
Doing it myself
It's just the water going septic if you're not using it often.
if the entire thing is sealed well, you shouldn't have any smells coming out of it. I'm going to go with the lid.
Journeyman Plumber |
| Display Modes | |
| Basement Shower Drain Gas Smell | ThunderCAT | Plumbing | 10 | 07-30-2009 03:04 AM |
| Tie into existing bath GFI circuit for new basement bath GFI? | 8roty | Electrical | 8 | 07-28-2009 12:38 AM |
| Sewer gas smell in basement when doing laundry on main floor | Bornintc | Plumbing | 1 | 01-17-2007 12:04 PM |
| Drain connection for basement utility sink | chickenboo | Plumbing | 5 | 09-11-2006 03:30 PM |
