Basement Bath Rough In ID - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2013, 04:39 PM   #1
basement bath rough in ID
Ok pic one of the trapped shower drain is from the middle of the bathroom. Pics two and three are 180 from that.
My questions:
1) is the pipe to the right my sink drain? That one, the toilet drain and the shower.drain on the opposite side are the only pipes in the bathroom roughed in.
2) I have 1/2" flowguard lines above where the sink and toilet will be. I'll definitely be coming off of a 1/2" supply line for the sink and shower hot water. There is a 3/4" cold line about 8' away. Should I extend the 3/4" supply line to the sink and toilet area and run them down the wall off.of that? At least one other bathroom on the upper levels feeds off of those 1/2" lines as well since they go up through the ceiling.
Thanks for any assistance!
nbcarr1 is offline   Reply With Quote
Old 10-15-2013, 06:00 PM   #2
DIY staff
Rewards Points: 7,174
Right pipe --is that 2" ?---I believe that is the vent--and could be used as the drain for the sink----
Old 10-15-2013, 06:26 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 922
Why is there a 3x2 san tee in the ceiling? Must be a vent? You can not use that tee for a drain. Should be a wye instead.
Where is the toilet located in the 3rd image?
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (10-15-2013)
Old 10-15-2013, 06:30 PM   #4
Plumber
Rewards Points: 922
I believe you're right, but my code would require a vent on the shower as well.
nbcarr1-- what code are you under? Can you give us a location?
Old 10-15-2013, 07:52 PM   #5
I am in Baltimore county Maryland.
The pipe with the tee isn't connected with the alleged sink drain if I recall correctly. Let me check on it...
Old 10-15-2013, 08:05 PM   #6
Plumber
Rewards Points: 922
I was confused by the pictures- that 3" is in the ceiling above the shower- must be a vent for the upstairs toilet. It wouldn't pass inspections here but obviously has in Maryland. It has no bearing on the basement plumbing
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Valid vent for basement bath? bdowden Plumbing 4 09-30-2011 03:43 PM
Basement bath plumbing rough in allowing ground water to enter VooDu Plumbing 1 01-07-2010 01:09 PM
Tie into existing bath GFI circuit for new basement bath GFI? 8roty Electrical 8 07-27-2009 11:38 PM
Basement 1/2 bath--full bath conversion Demochick Project Showcase 2 06-30-2008 09:03 PM
