Old 01-03-2010, 12:26 AM   #1
Basement bath plumbing rough in allowing ground water to enter
We have a full bath in our basement. The plumbing for the shower has a 10" deep square hole cut in the foundation to allow for the shower drain trap. This hole is lined with a thick black material. However, it has a hole in the bottom about the size of a quarter. I assume this is to be used as a drain in case of a leak (I have inspected the plumbing and can find no leaks). Since their is about 3/8" of water in the bottom of this hole, I am assuming the ground water is coming up through this quarter sized whole(we are experiencing extremely high water table -- the highest in 30+ years).
I would like to find something that would plug this hole. Maybe some type of water proof epoxy.... something... that I could cover the hole with and then dry up the existing water in the hole.
Any advice or help on this would be greatly appreciated.
VooDu is offline   Reply With Quote
Old 01-07-2010, 02:09 PM   #2
a sump pump
rudolph58 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
what to do for plumbing rough inspection? red86yota Plumbing 5 09-12-2010 05:39 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
