Old 09-27-2011, 12:47 AM   #1
Basement bar sink drain/vent advice
We're in the process of finishing our basement. The water coming into the house comes up about a foot away from the wall in where we want to have a family room.
To hide the water input pipe, we'd like to build a bar in that area with a sink, about where the unpainted brick is in the photo. My question is how would I drain and vent a sink near that pipe.
To finish the brick walls, I'm planning a layer that looks like: http://hostedmedia.reimanpub.com/TFH..._FIFOUW_01.JPG
Would it be up to code to run the drain line inside of the wall that will be covering the brick? The drain line would probably be about 9 feet long.
Or would I need to dig into the slab and bury the drain line?
I'm not sure about how to vent it. The closest vent through the roof is the one used by the upstairs tub. That is about 5 feet away from the water pipe and about 4.5 feet from the brick wall.
thanks,
Jeff
repoocaj is offline   Reply With Quote
Old 09-27-2011, 04:18 AM   #2
Yes, the drain and vent can be inside wall. And I think it is 5 feet max without it's own vent.
JIm
jamm51 is offline   Reply With Quote
Old 09-29-2011, 11:02 PM   #3
Jim,
Again, thanks for the info. I had a plumber out today and he suggested that we have the tub drain down under the slab since we'll have it open anyhow for moving the toilet and shower drain around. Then we can probably drain the bar sink into that as well.
thanks,
Jeff
Sink In The Basement cubfan12 Plumbing 2 10-30-2010 07:56 AM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
Repair Utility Sink in Basement lincolnparkjok Plumbing 3 10-06-2010 09:38 AM
Advice for a novice: Mold and water damage in basement xoxJanette General Discussion 1 12-29-2009 07:54 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
