Basement Bar Sink To A/C Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2014, 05:41 PM   #1
Basement Bar Sink to A/C drain
I know nothing about proper plumbing so excuse my ignorance but I am wanting to know if its possible to install a sink that drains into the a/c condensation drainage in the basement floor? I am wanting to add a sink to my bar area and the a/c drain is located about 2 feet behind the bar.
dtuffy118 is offline   Reply With Quote
Old 11-06-2014, 06:21 PM   #2
Rewards Points: 1,776
Nope it must go to your sanitary drain.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (11-06-2014), plummen (11-09-2014)
Old 11-06-2014, 07:04 PM   #3
Thanks for the prompt answer.
So the condensation drain must be a sewer/septic drainage?
Old 11-06-2014, 07:14 PM   #4
Rewards Points: 582
picture of drain area..maybe your condensation drain is already part of the sanitary drain system.. if it is...break up concrete tap into pipe run to bar sink make sure of proper vent ....job done..
Old 11-06-2014, 09:36 PM   #5
I wouldn't know. Is it a floor drain that your condensate is going to? Pictures a worth a thousand words. I have seen condensate run to footer drains. That is not a sanitary drain. A drain that is attached to your septic or sewer is considered sanitary drain. The waste water is treated. Your question was if you could run a bar sink to a condensate drain. Not sure what your calling a condensate drain.
Old 11-06-2014, 09:56 PM   #6
Rewards Points: 3,130
If you are talking about a typical air conditioner condensate drain, it is most likely too small to qualify as a sink drain no matter where it drains to. I've never seen one larger than maybe 1 inch.
Old 11-07-2014, 02:24 PM   #7
Pic
Thanks All! Here is a pic of the drain
Basement Bar Sink to A/C drain-img_0766.jpg
Old 11-07-2014, 03:41 PM   #8
Rewards Points: 268
Is this on a city sewer or septic? If it's a septic, it's unlikely that the floor drain is tied into the septic because people don't want their softener dumping into the septic.
BlackTiger is offline   Reply With Quote
Old 11-07-2014, 04:11 PM   #9
Drain
Im really not sure where the drain goes. I just bought the house maybe 6-7 years ago. 35 year old house.
Old 11-07-2014, 07:30 PM   #10
Is the pipe your toilet flushes into above your head? Does that pipe go out the wall to the septic or into the floor then out to the septic.
Old 11-07-2014, 07:32 PM   #11
Rewards Points: 268
Are you in town or in the country?
Provided that floor drain is tied into the rest of your plumbing, you're looking at doing what an earlier poster said about breaking up the concrete and cutting the floor drain's horizontal pipe in order to insert a wye.
There are other, far less finished solutions possible, but all of them would be ugly. Also remember that the drain will need to be vented, or it won't drain properly. Sort of like when you try to pour soda out of a brand new bottle.
The Following User Says Thank You to BlackTiger For This Useful Post:
Javiles (11-07-2014)
Old 11-07-2014, 08:54 PM   #12
Master Plumber
Javiles's Avatar
Rewards Points: 990
. Sort of like when you try to pour soda out of a brand new bottle.[/QUOTE]
I like that comparison!!
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 11-07-2014, 10:23 PM   #13
There are 2 bathrooms above and have 3 drains(not sure if toilet or sink/shower) feeding directly into a large diameter PVC that goes into the floor. This drain into the floor is about 2-3 feet from the a/c condensation floor drain.
Live in the city.
Basement Bar Sink to A/C drain-img_0775.jpg   Basement Bar Sink to A/C drain-img_0774.jpg
Old 11-08-2014, 09:45 AM   #14
Rewards Points: 268
It'd probably be a lot easier to cut a wye into that vertical drain pipe than it would be to tie it to the floor drain ' pipe
Old 11-09-2014, 10:11 AM   #15
If that 3 inch stack by your bar location it would be easier to cut in a tee and run it to your bar through the walls then add an AAV under the bar sink. By the way it seems to be missing its clean out at the base.
Tags
basement drain , hvac , plumbing , sink drain
Old Basement Sink Drain - Clay? maybere Plumbing 7 09-27-2011 12:49 PM
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 02:30 PM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 06:36 PM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 09:36 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
