Old 08-31-2012, 02:44 PM   #1
baseboard help
jus converted my old cast iron radiator to a base board heater. Installed it myself (not my first one) went to turn on heat to check for leaks now i can't get the water to come to the heater. I have installed bleeder valves on the heater still can't get the water to rise. ( heater on second floor) all the other heaters in the house are working and getting heat. please help stuck
Bigpetey is offline   Reply With Quote
Old 08-31-2012, 02:50 PM   #2
baseboard help
what's your boiler pressure?
takes 10 pounds just to get to the second floor.
you may have to raise the pressure up to 15-20 so you can bleed it then drop it back down.
i used to have to raise the pressure up to 25lbs so one of my customers could bleed the radiators on the 3rd floor then i would drop it back down.
The Following User Says Thank You to DannyT For This Useful Post:
Bigpetey (08-31-2012)
Old 08-31-2012, 03:21 PM   #3
baseboard help
how do you raise the pressure if i m reading this properly i have 0 pressure
Old 08-31-2012, 03:50 PM   #4
baseboard help
do you have an autofill valve on the boiler or do you have to manually fill it? did you turn the water back on to the boiler after you installed the baseboard?
Old 08-31-2012, 04:10 PM   #5
baseboard help
auto fill and no i didn't close the bolier down, i only drained the pipes going to the cast iron heater upstairs.
Old 08-31-2012, 06:39 PM   #6
baseboard help
but you said you had 0 pressure. is the autofill working properly? i would add water to get your pressure up to 15-20lbs and then bleed the unit up stairs. after you bleed the air out you can drain enough water out of the boiler to reduce the pressure back down to normal working pressure. how did you drain the lines to the radiator you removed without shutting the boiler down?
Old 08-31-2012, 07:07 PM   #7
baseboard help
i had redone the plumbing in the house about 6 years ago. I set up valves to shut the the feeders and a drain so i can drain each radiator without shutting down the boiler. I really don't know how to bring the pressure up on the boiler. Do i just starting filling the boiler up i see a valve shut off ,which is the water coming in before a regulator. do i have to shut anything down prior to doing this.
Old 08-31-2012, 08:18 PM   #8
baseboard help
you really should not mix....cast iron rads with copper fin...don't work that well...different operating temps.....but as it is raise boiler pressure and open bleeders till you get water....
Old 08-31-2012, 08:24 PM   #9
baseboard help
no just open up valve to boiler regulator till it builds pressure if that is not enough .open by pass lever on regulator to a little pressure higher than the set pressure....you should get water...ben sr
Electric Baseboard Heater Questions mark2741 HVAC 0 12-31-2010 01:08 PM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 10:48 PM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 05:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
