-   -   Baseboard Heating Stops Getting as Hot as it Used To? (http://www.diychatroom.com/f7/baseboard-heating-stops-getting-hot-used-38143/)
kali 02-11-2009 03:46 PM
Hello,
The baseboards in my one bedroom condo have been working well all winter. However, a few nights ago, they just stopped heating up completely. Usually the top of the baseboard is hot to the touch. This is no longer the case. While the pipe on the inside of the board is hot, and the boiler appears to be in working order, the board itself is just NOT heating up completely anymore. The apartment is notably colder, and the thermostat is not going past 78 (I have very poor circulation and generally keep it at 85-90.)
I know NOTHING about plumbing, baseboard heating, etc. Can any one tell me what might be wrong?
Thank you so much!
Kali
AllanJ 02-11-2009 05:44 PM
Probably too much air got into the system.
Since you said you don't know much about the system, I will have to suggest that you get a professional in to bleed the system, add more water if needed, and also tune up the system.
kali 02-11-2009 06:49 PM
Thanks so much for the reply.
It is a new construction, so one of the guys who worked on the project supposedly bled the air. I watched him do it - he just let the hot water run out for a few minutes. Since it didn't "choke" or stop up, he said there was probably no air and that everything was fine.
Where would more water need to be added, and what would need to be tuned up? Sorry to ply you with questions. When a plumber comes in here (generally a male) they usually try to take advantage of a young girl like me.
Any help you can provide so I can appear somewhat knowledgeable is EXTREMELY appreciated.
jerryh3 02-11-2009 06:54 PM
Where are you located? The system may have an outdoor reset which would have lowered the water temperature if the outside air was warmer than usual. Or, if it was really cold, the boiler may not be able to keep up with that high of a demand. Can you take a picture of the boiler and the aquastat(probably a gray box somehere on the boiler). And how young are you that you keep the temp at 85-90?
kali 02-11-2009 07:14 PM
I'm in the New York City metro area. This did start when it got incredibly cold, but now we're unseasonably warm and it's still not working.
I'm telling you - I have terrible circulation at 27. It's scary. Plus the insulation here is awful, but that's another story.
I will get a picture by tomorrow. Thank you so much!
AllanJ 02-12-2009 08:45 AM
Is the furnace for your condo unit only, or shared by all the units (apartments)?
For a shared furnace and also for a few individual furnaces, the thermostat activates a circulator motor or a plunger valve. Should these components be defective you can get less heat than you should.
Are there any knobs or user adjustable valves on the baseboard heaters that are exposed and might have been twisted accidentally?
Also, things such as sofa slip covers should not obstruct the bottom slot and louvers of baseboard heaters and the insides of baseboard heaters should be vacuumed out periodically (careful, very sharp edges).
kali 02-12-2009 02:47 PM
2 Attachment(s)
I am attaching pictures of the boiler in question, but they aren't very good due to the file limitations on this site.
The boiler is for my unit only. No knobs or valves anywhere. Any other thoughts?
Any tips on how to get in there and clean the baseboards without damaging them? They seem so delicate.
Also, I don't think that's the ultimate problem considering every baseboard is experiencing the same problem.
Thanks so much!
Kali
jerryh3 02-12-2009 03:08 PM
Thanks so much!
Kali
Try playing around with the image size again. You should be able to post a little bigger picture.
