Baseboard Heat Not Enough... - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-06-2010, 08:25 PM   #1
Rewards Points: 252
baseboard heat not enough...
Hi all,
I have a small bathroom on the main floor of my house (about 3'x5'). There is a door in this bathroom leading to my backyard and the bathroom is in the corner of the house - so two exterior walls. This bathroom gets COLD in the winter - even with me sealing up the door pretty tight. The only heat in the bathroom is a 30" hot water baseboard. Anyone have any suggestions on what I can do to increase the heat output? Would it make sense to change out the baseboard to a runtal radiator? Any other ideas? suggestions?
thank you !
Matt
mazzonetv is offline   Reply With Quote
Old 12-12-2010, 05:06 AM   #2
European Radiator
I was just looking through runtal radiators and similar radiators. I came across this on amazon, http://amzn.com/B002LLN7TC
Unlike the runtal, which is made from steel. That one is made from aluminum. Higher BTU as well.
dapro is offline   Reply With Quote
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
heat not circulating to baseboard needhelp56 HVAC 8 02-28-2010 07:05 PM
Baseboard Heat 80% Rule Question bltglt507 Electrical 1 11-06-2009 12:17 PM
electric baseboard heat drewhart Electrical 21 11-05-2009 09:12 PM
Help with bleeding baseboard heat system robinswendy HVAC 1 12-13-2008 05:04 AM
